I want to share my solar experience with everyone on this forum. Half of the cost of a PV system is in the installation cost, so I decided to do that myself and post it here so it might help you.
First, a picture:
![DIY Grid Tie 5.1kW for $0.77/kW DIY Grid Tie 5.1kW for $0.77/kW](https://www.hearth.com/talk/data/attachments/154/154625-f4f793002672ecf1dbf0d686e2da6f9f.jpg)
And the details:
SMA Sunny Boy 5000-TL-US
20 REC 255 pV panels
![DIY Grid Tie 5.1kW for $0.77/kW DIY Grid Tie 5.1kW for $0.77/kW](https://www.hearth.com/talk/data/attachments/154/154626-065d5d97f33284b43ddcfb7b2c803ce3.jpg)
Snapnrack roof mounts (composite shingle) with flashed L feet
I bought the system as a kit, it came with all the Snapnrack mounting and grounding hardware, 2x 50' PV cable with MC4 connectors, a couple of Midnite Solar surge protectors.
Total kit cost was $8500, with another $300 for shipping. I had it shipped to my business address and unloaded the semi with our forklift and hauled it home in my pickup to save another $300 for drop gate service to the house.
I had done my homework on my roof (35 latitude, 150 azimuth, 45 degree pitch) and had my system sized for it.
I then went out and started shopping for local installers. The first installer quoted me $10,500 and I quit right there. That's more than another whole system. Also, keep in mind that your solar installer needs to be a licensed electrical contractor and that your quote for any electrical work needs to be between you and the actual contractor, not a third party solar installer.
Well, the parts arrived Nov 21 and to get the tax credit in NC, the system has to be functioning that year. So, here is my guide for a handy homeowner to install a grid tied solar system in just over a month in Buncombe County, North Carolina:
Get your building permit. I am outside the city limits, so no structural analysis had to be done on my roof. It is a two year old stick built house with 24" spacing between the rafters, just FYI. Apply as the General Contractor and pull a building and electrical permit. Each one of these is $75, so I spent $150 here. I had a licensed electrical contractor that was running the connections from the array junction box to the service entrance, so I listed him as the electrical subcontractor. In Buncombe County, NC, you can act as your own General Contractor on your own house for projects under $30,000. Also, as the homeowner, doing the work on your own house, not for sale or rent, you can do ALL your own electrical work. This is listed in NCGS 87-43.1(5a). This is how I was able to legally install the solar array on my roof.
Apply for interconnection with your local utility. I am on Haywood EMC, which is a co-op. I just applied on their website and got the go-ahead. Their max for residential is a 25kW system and they do net metering. When you finish your project and it passes inspection, they come out and install your two way meter.
Now, the parts and the paperwork are done. Next comes the fun part: installing the array. If you are moderately handy and you have a roof pitch of 7:12 or less, then you shouldn't have any trouble. I had a pitch of 12:12 (45 degree) and this brought more work. First step was to climb up to the top of the roof and take off one of the ridge vents and install the roof anchor for the safety harness/fall arrest system. This is the most dangerous part, but also one that gives you the most safety for the rest of the project. After this, clip in to your anchor wearing your harness and install your roof brackets so you can put in the top row of rails and panels. Here is a picture of this:
![DIY Grid Tie 5.1kW for $0.77/kW DIY Grid Tie 5.1kW for $0.77/kW](https://www.hearth.com/talk/data/attachments/154/154627-3c50d912324129df73447d1740bfb946.jpg)
Here is another pic from the ground showing other roof brackets:
![DIY Grid Tie 5.1kW for $0.77/kW DIY Grid Tie 5.1kW for $0.77/kW](https://www.hearth.com/talk/data/attachments/154/154628-18d8858d835d5d438b3c1b04c707810d.jpg)
This allows you to work on a steep slope safely. Of course, when you finish one row, you remove and reattach the roof brackets for the next row. Once you figure out how to mount one L foot, the rest are all the same. Same goes with attaching the rails to the mounting feet and panels to rails. Before you know it, your 20 panels are up and ready to connect. Be sure to do a string connection diagram so you know where each panel is going to be hooked up to and always leave one connection unhooked (the easiest one preferably) until last.
This whole process took me about 5 whole days, and had the electrical contractor out there two of them. We even worked Christmas Friday to get it in by the end of the year. One detail I ignored until it was almost too late was the labeling of the solar system
![DIY Grid Tie 5.1kW for $0.77/kW DIY Grid Tie 5.1kW for $0.77/kW](https://www.hearth.com/talk/data/attachments/154/154629-cf35105c9adc908e55b56d01176cb9e5.jpg)
It was too late to ship labels, so I had a local graphics company print me some so I would be sure to pass inspection. Inspection came on 12/30/14 and we passed at 10AM, and the Co-op hooked up our meter around 3PM.
So, cost of system: $8800
Permits: $150
Safety Harness, stainless lag screws, roof anchor, roof cement, roof brackets and lumber, other parts: $400
Electrical Contractor: $1900
Total cost: $11,250.00, which would be $2.20 per kW without incentives, but:
less 30% Federal and 35% State Credits: $7312.50
Total out of pocket cost: $3937.50, so more like $0.77 per kW
I welcome all feedback and comments.
Here is what makes it all worth it:
![DIY Grid Tie 5.1kW for $0.77/kW DIY Grid Tie 5.1kW for $0.77/kW](https://www.hearth.com/talk/data/attachments/154/154630-acdb30603642486548d1ac67e9ec50a1.jpg)
I had a few surprises:
I thought I could mount all 10 top panels and then 10 more on the right side of the roof. I ended up only mounting 6 on the right and 4 on the left. If you notice in one of the pictures, the edge of the panel is really close the the valley of the roof. I made it work. This mistake actually bugs me because I thought I had planned out everything. The steepness of the roof prevented me from getting all actual measurements, so I took a couple and then extrapolated the rest using Google SketchUp. This is a great planning tool, but remember that a computer is only as good as its inputs...
Other thoughts:
PVwatts puts out 6855 kWh/year on my system
The inverter has the wiring for the SPS, I just haven't connected it yet. I was in a time crunch to get this install on my 2014 taxes, so I left out that part of it. The shading you see was at 3:53 PM on Jan 10, and that was just the way it is. As the days get longer, that shading should diminish or at least be still about 30 minutes before the sun hits the tree line 150' away. I did wire the two strings to be on the left (West) and right (East) sides of the roof, so each string (and corresponding MPPT, the inverter has two) would be as similar as possible within the string, and one would maximize the morning sun and one would maximize the evening sun. The right (East) string includes the top right 4 panels and the panels directly below them (4 then 2). In a perfect world, I could have used microinverters, but that late in the day in the winter, it is not going to significantly decrease my power generation. I guess no one says "acceptable shading" in the solar world, but this is my thinking on it. I also want to leave myself the option of adding a battery bank in the future that would be grid interactive.
Also, I haven't stated this yet, but I am just an amateur with this whole solar thing. I think I have researched everything right and done everything right, but I very well may be very wrong. This is why I put my system out there so I can get the feedback.
With the drop in solar pricing now, I do think that you need to grab the bull by the horns, though. Solar is only about 3 years from being mainstream in my view, at least in my hometown.
Anyways, here are a few more of the photos of the finished install:
![DIY Grid Tie 5.1kW for $0.77/kW DIY Grid Tie 5.1kW for $0.77/kW](https://www.hearth.com/talk/data/attachments/154/154644-8cb940bb65ce89d6a4dff0b2764f03bd.jpg)
This is the service entrance on the side of the house with the two way meter.
![DIY Grid Tie 5.1kW for $0.77/kW DIY Grid Tie 5.1kW for $0.77/kW](https://www.hearth.com/talk/data/attachments/154/154643-e32a940592e9f1ef0f4e9bd65725e673.jpg)
This is the open service entrance, which has has small panel that we installed the 30 AMP breaker in that feeds the solar to the house from the inverter. This made it easier, ran less wire, and didn't take up more room in the main load panel.The local utility (Haywood EMC) requires the separate AC disconnect even though there is a 200 AMP breaker that they could cut off. I do like the fact that we can isolate the inverter without cutting all power to the house.
This is the junction box and dc conduit up the side of the house.
![DIY Grid Tie 5.1kW for $0.77/kW DIY Grid Tie 5.1kW for $0.77/kW](https://www.hearth.com/talk/data/attachments/154/154646-d194552b762b1837a776466a79414368.jpg)
A closer shot of the junction box, at least from the ground.
![DIY Grid Tie 5.1kW for $0.77/kW DIY Grid Tie 5.1kW for $0.77/kW](https://www.hearth.com/talk/data/attachments/154/154648-07f6d0c5d8fe7b5cfb2a2dec4958fd21.jpg)
First, a picture:
And the details:
Permits: $150
Other thoughts:
