You gotta be burning a hell of a lot of gas thru a saw, before price matters on that stuff. Bar oil... sure. But 2-stroke mix? C'mon...The real question is what is the difference between the 3 stihl flavors and other high quality oil of the same flavor?
when mixed with premium ethanol free it is about a $10 gallon of gas/mix![]()
I know this probably borders on sacrilegous, but I've never had any problem running regular with ethanol in any of our two strokes, either for small equipment or outboards. The key is to use all the gas in the equipment tank, and seal the 5 gallon jug or whatever so that it doesn't pick up any water from the air, or offgas any of the more volatile components. We cut a few cords a year with an 036-QS, an 021, and an older Homelite, but generally try to squeeze it all into a few days. Of course, YMMV, but I don't think premium non-ethanol is really worth it for anything outside of racing and aviation applications. (In aviation it's important because ethanol changes the vapor pressure, which isn't a big deal at normal elevations, but can be problematic at 15k ft.)when mixed with premium ethanol free it is about a $10 gallon of gas/mix![]()
I can cut enough wood with that gallon of gas mix to replace $2k in heating oil. Besides, your cheaper 2-stroke mix takes that cost down to, what... $8.50?when mixed with premium ethanol free it is about a $10 gallon of gas/mix![]()
I pay less than $4 gallon for premium non E and buy a bottle of husky oikd for like $4 or less and make 2.5 gallons so I'm still less than $6/gallon??when mixed with premium ethanol free it is about a $10 gallon of gas/mix![]()
for me anyhow . A bit more if you count in my chiropractor
WTF?
What are you using?
# of oil refineries owned/operated by Stihl = 0
# of oil refineries owned/operated by WalMart = 0
# of oil refineries owned/operated by Husqvarna = 0
# of oil refineries owned/operated by Poulan = 0
etc. . .
etc. . .
etc. . .
I've never seen it priced like that around here. You need a new dealer my friend. That's ok tho. I was forced to buy a fuel line for an MS390 from a dealer I don't normally use. $16 and change. Yeah he stuck it in deep. Still hurts.$5 for stihl ultra galllon mix
The first syllable out of the kids mouth was "Twen..." Too bad I needed the line so badly, I would have thanked him for his time and left otherwise.
