Well thanks to all who are reading this, I've never posted before so here goes.... You may say that I'm crazy but join the club, I'm volunteering at a Christian kids camp called God's mountain in Missouri, I was about to hook up an OWB with an oil gun to a couple of the buildings....when I thought what if I made a mega boiler that would heat the whole camp.....crazy yes...The camp supervisor showed me an 8x16' tank on top of the hill 1/4" mild steel, and my wheels started turning, there is also a 7x14' tank the first tank could hold 6100 gallons of water, the second 4100 gallons.....The requirement, a total of 26952 sq. feet of different buildings to heat, minimum 18192 sq. ft if you subtract the garage(1400), gym(3360), and one of the basements(4000)... So there is a ton of requirement, here is my idea, I would like to build a switzer/garn style boiler inside the 6100 gallon tank, heating primarily from wood, but also set up with an oil gun(we have a ton of used motor oil 1300 gallons plus, and it keeps comin)the 6100 gallon tank would run in tandom with the 4100 gallon tank for extra storage. The second thought is actually running a geothermal loop(horizontal...we have property) and using the 55 degree ground water in the summer through the heat exchangers inside of our buildings, this would cool the buildings in the summer, winter comes we would turn off the geothermal loop and fire up the boiler and use that for heat. The question here is would that work? I've heard that the temperature differance is not extreme enough to cool off the air, but 55 degree water should cool off the air shouldn't it....second if I did do this about how much piping and what size would I need...? Okay back to the boiler, I would like to know your thoughts on firebox size and piping size as far as the heat exhangers inside the boiler example switzer uses i believe 9 2" tubes and 3 passes. the garn uses a single 4" maybe, never seen pictures.... how would I calculate to know how big the firebox would have to be to heat up 10,000 gallons of water...I know I know....you are saying this guy is loco.....yup...but for Jesus...... I would appeciate any dialog you all could offer, I find that others are normally smarter than I so I need your help thank you so much
Bryan
side note I also have a couple of other tanks that I could use one 8x16' two around 9x25' crazy big tanks....just throwin that out there
Bryan
