What chain do you have on that 290? If you're still using the semi-chisel low kickback chain that it came with (RMC3 or RM3), then try a loop of full chisel yellow chain (RS).
"Firecracker, you think that white oak is dense.....wait till you get into a full day of cutting huge locust rounds up......"
Cant tell much of a difference for me.
I second that. Those safety chains are dog doo. A 290 ought to be plenty to deal with 20 inches of oak. I work 30 plus inches of oak with a 250. The 250 does great with a sharp full chisel chain. If the chain even comes close to the ground it needs to sharpened.
Is this what you are referring to?
http://www.stihlusa.com/products/chain-saws/saw-chains/rsf/
I'll try it if it's faster and cuts better.
Standard 3/8" x 0.050" full chisel chains from Stihl: 33-RS or 33-RSC.
Basically, the full-chisel chain has a cutter that, when viewed straight on, looks like a sharp "7". A semi-chisel chain has a cutter that, when viewed straght on, looks like a rounded "7" or a "?". That's issue no.1, and it doesn't really matter so much who's full-chisel you use, as much as whether it's full or semi-chisel.
Your second issue is safety vs. non-safety chain. A standard (non-safety) chain has only one depth gauge in front of each cutter. It's actually stamped onto the same link as the cutter. A safety chain will have some sort of secondary bump on the tie strap in front of the cutter link, whether it be a full ridge back, or just a smaller bump that aligns with the depth gauge while the chain is straight. This is likely your biggest issue, when burying the nose of the bar in a bigger log, as safety chain does NOT cut well with the nose buried.
Full-chisel will cut a little bit faster than semi-chisel, when sharp, but it dulls quicker. That's the primary advantage of semi-chisel, and why it's usually spec'd for homeowner / ranch grade saws. If your saw is struggling, I suppose full chisel may help, but you also may find it's more grabby... counterproductive. Your bigger issue, when burying the nose, is probably safety (green label) vs. non-safety (yellow label).
BTW... 33-RS/RSC = yellow. 33-RS/RSC-3 = green. All full chisel. The "-3" is the option for the safety link.
I never have locust come my way. I'm pretty much at the mercy of what the tree services bring me. I could get some hickory or a lot more oak logs if I want them.
For sure I'd grab all the hickory you can get! Get the oak too if you have room to store it a few years before burning it.
"So does this thing kick-back a lot? I don't want to lose my face."
Don't worry too much about kick-back. I've always thought this has been overplayed for many years and it is getting worse. I've but a bit of wood in my time and have never been concerned about it nor have I experienced it.
So you never had the top of the bar nose contact something, even a twig or a branch, and the saw rock back, even a little? That's amazing.Don't worry too much about kick-back. I've always thought this has been overplayed for many years.........have never been concerned about it nor have I experienced it.
Contrary to what Dennis says, I would say, be concerned about kickback and be aware of where the nose of the bar is at all times, especially when cutting in heavy brush, be cause kickback does happen. And don't rely on the chain brake to save you from a mistake. Keeping your left arm straight when possible is another precaution you can take, as is keeping you thumb around the bar.
The number of situations where a green chain would save you from a mistake are very limited.
In addition to the basics- cut it fresh, not dry, if at all possible.
Having cut fresh vs drying- I get MUCH easier cutting with just felled. This was especially apparent when I went to buck up red oaks that I had girdled vs fresh ones.Why's that? Always seems to me that green wood requires more HP than dry.
