Poindexter
I had a separate measuring stick for a while, put a mark on my woodchuck hookaroon thingy instead, one less piece of gear to lose in the woods.
I do fine with one piece of yellow and one piece of blue sidewalk chalk in my saw box. One or the other shows up real nice.
I probably will try a pair 10d or so nails connected with a 16" piece of string someday. For that to work good I want the nails to be big enough to grip easy with gloves on, but small enough to pocket easy.
The hookaroon with the mark is 32", I just used a permanent marker 16" from each end.
If I have a helper with me, I get them to do the same thing with the bush axe and chop a mark where to cut.
This one is quite a bit easier to lug around than the McColluch Timber Bear that cut the logs to buy the saw (13lbs. vs. 18lbs)
