Bowhunter1
Burning Hunk
UPDATE: Turned off the stove today to fire pot/holder. Every pellet burned with the fan running! It did not smoke the pellets out after like before. Took out fire pot, burn plate then took off 4 screws that holds the casing of firepot. Tons of ash under it, vacuumed all that out. Decided I would remove baffles, heat exchanger was very dirt (both were cleaned 2 weeks ago). Cleaned all that up including top. Checked every hole on fire plate and used drill bit to clean a few out better. Did the same thing for the burn pot (only 2 were clogged).
Decided to put it all back together but forgot to take picture of burn pot! Started it up and still had a lot of smoke in chamber again. Not sure what that is about (not windy). Stove is cranking out good heat again! Think the exhaust fan being so dirty was creating the low heat and making things super dirty (usually clean heat exchangers monthly). With the low heat stove was having issues knowing there were pellets in there.
Thanks so much for all your advice! If you know of a service tech in the Lansing, MI area please let me know! Obviously I need a new one.
You can do the cleaning yourself it doesnt take a lot of time:
