Creosote remover with cat
I wouldn't. A chimney brush or soot eater is all you need to remove creo from the pipe, and a good hot fire is all you need to flake it off the firebox.
Mfg says not to use such logs
Reactions: Ashful
I believe in the past when this was brought up it fell into the “ not recommended” category.
Reactions: Ashful
The crystals is the same active ingredient that harms cats.
Reactions: Ashful
Are you seeing a particular problem that's making you want to go this route? Or is this just a, "I have them, so I want to use them" scenario?
Reactions: stoveliker
Ha. Kinda both. I have always used them with my non-cat stoves so I have some on hand. But I also want to be sure #1 I keep the stove and pipes clean and #2 not damage the cat (this is my first cat stoves). It looks like using these is not a good idea.
Reactions: Tron and Ashful
To get a bit scientific here: the Rutland Creosote remover contains mainly Sodium phosphate (although they don't state the percentage).
Phosphates are generally a bad idea with noble metal catalysts, the can cause (reversible) glassing with P2O5, poisoning the cat, but also irreversible damage by turning the ceramic substrate into phosphates. See here for an abstract of a paper:
Nothing but cord wood in a cat stove. I would not even use paper a starter. But that’s just me.
The BK manual says black/white newspaper is fine.
Don't do shiny paper or colored paper.
Reactions: jimehrhard
I think there are better fire starting materials than paper. How many papers these days are black and white? (I don’t get any but even the WSJ has quite a bit of color. )
