My wife and I recently moved to a house which has an Alpiner wood furnace. I believe this is basically a knock off of a Fisher Papa Bear, and was made at some point prior to the late 70s.
This morning, my wife noticed that there is a crack along the top of the firebox which you can see light through. My guess is it's been there all along; you have to be standing to one side with the room lights off to see it. Note that this stove was inspected by both a home inspector and chimney inspector. The chimney/fireplace people saw no problem with it; the home inspector noted that the manifold had a crack implying that there had been very hot fires there at some point. (I've used a surface thermometer to keep it from burning hot since we've been here).
I am trying to understand if this is something I can think about repairing, with stove cement or otherwise, or if we need to just not use it and replace it. We have oil heat, as well as another wood cook stove on another level, so we can stay plenty warm in the meantime.
Here are pictures with the room lights on and off:
![Crack in Alpiner furnace Crack in Alpiner furnace](https://www.hearth.com/talk/data/attachments/218/218439-d664672c02f2707e17769a4566ef42e7.jpg)
![Crack in Alpiner furnace Crack in Alpiner furnace](https://www.hearth.com/talk/data/attachments/218/218438-4e10372a366f6aa25fdc2567306fe649.jpg)
