donmattingly said:Thank you for all the responses. The gentleman at the shop said it was most likely bad/old gas that killed the piston and cylinder which I believe. I remember the last time I used it after the October snowstorm, I just used the mix that could have been a couple of months old. The guy also said with all the crap they put in gasoline these days, it has a shelf life of about 14 days. I will be more vigilant now.
I think the gentleman at the shop was either full of whiskey or bull. You pick. Even bad gas is going to have the oil in it. Usually the P & C gets trashed from little to no oil or mega hours. A lean burner can do it too. You really should be finding out WHY it happened so that you can avoid the same with the new parts.
