All, thanks for all the good replies, I appreciate the input.
To answer a few more questions that have been raised, access to the "office space" is from a deck and the garage structure is next to a bank. If I get a stove then I will build a catwalk from the deck to the bank (almost level) which will get me away from the house and to the wood source.
The place I have in mind for a stove is the corner on your right as you walk in. I have quite a bit of open space there, and can provide 6' along each wall for the stove... 36 square feet. One of these walls has a window, is that a problem?
Originally I stated that I was looking for a long burn time... and after reading your input I'd modify that to: moderate, even heating. I have a friend who heats his house with a cast-non-cat stove and it always seems to be extreme heat "when he puts the wood to it". His house is big enough that this heat has someplace to go, but in my little space it could get overwhelming.
I have three 60" ceiling fans going into the space which (although slow speed) should circulate the air well.
Regarding a secondary heat source, I expect I'll have to put in something, if nothing else a few strips of baseboard heat to keep things from freezing if I am away.
Relative to cost, the Woodstock stoves which are on sale are within my budget. I also found a place that will sell me a F100 Jotul for (just) under $1k.
Thanks again,
-Ted
Thanks again,
-Ted
		 But other than that, there's nothing to using a stove with a catalytic combustor, at least a Woodstock.
