Branson4720
Burning Hunk
The Black Hills are super hotBoy thats saying alot for the Black hills This man got nothing but the bestI was suppose to be getting some to try, would of loved to be trying them in this cold snap
![Stick Out Tongue :p :p](/talk/styles/default/xenforo/smileys/raspberry.gif)
Smokey you must be living a cold spot. I haven't seen any temps in So. Maine anywhere near that.
Few people calling you out smokey... Just take a picture with something that shows the current date like a newspaper and put all the naysayers to rest. LolLots of cold spots in (southern) Maine just get out of the built up areas and away from the coast.
Few people calling you out smokey... Just take a picture with something that shows the current date like a newspaper and put all the naysayers to rest. Lol![]()
I'm not calling him out. I've got no reason to do that.
i'm not calling you out either. still getting used to even living here.
it also seems like a lot of places south of me in other states were way colder too.
some big blast rolling in off the lakes perhaps.
i have put a second thermometer outside (analog) to try and get a feel for the accuracy of my digital one.
ok. so torrefied wood pellets.
i have seen at least one article that seemed to be saying they could be used in regular pellet stoves.
i'd guess you would just mix in a small percentage with regular wood pellets.
since they supposedly burn 30% hotter than coal.
the feed rates would be way too high i'd have to think of a stove designed for wood pellets.
......................... .......... information though.
Wasn't trying to start trouble. Just seemed like you were defending yourself and figured the best way would be to post a pic because as we all know..... PICS OR IT DIDNT HAPPEN! :DI have no problem with your comment subsailor, I used to live on a man made peninsular where the temperature varied several degrees from one end to the other and a little over 7 miles towards the mainland it normally varied 10 to 15.
Torrified pellets would work in the pellet stoves with a little modification. The feed timer, whether mechanical or electronic, would have to be modified to slow the feed rate to about 80% of the rate of feed for wood pellets. The hopper then would last longer, but the stove was designed to have a maximum heat output and that should not be changed. The benefit would be that the volume of stored pellets would decrease significantly because of the higher energy content of the torrified pellets and the higher density of the new pellet. More energy would be in the hopper and so a full hopper would last approximately 40 to 45% longer. Another advantage would be that moisture and humidity would not affect the moisture content of the torrified pellet as they are not hydroscopic and are more like coal when stored. Of course all of this comes at a higher price. How much higher is not known at this time, but to sell, it must be competative.
A good amount, if not all, of the fuel source to heat the wood to torrify it comes out of the wood as VOCs in the process. They are collected and mixed with air to create the heat needed in the process.I believe it will be at a higher cost. The pellets are still made the same way and then your adding the time/energy to heat them. More labor and resources have to add to the bottom line.
We should start a thread on this subject. I bet it draws a crowd.
There are some weekly meetings several of us should attend.
I got rid of meetings a long time ago along with pagers, cell phones, and various other annoyances.
Just leave me alone and let me be warm. I don't need no stinkin' meetings.
alway being dissatisfied with that big ash clump forming in the burn pot. The MWPs don 't do that.
Neither kind of MWP make clumping ash. I have had more loose ash in the burn pot with the softies so I cleaned it out on the second day. I've only burned 7 bags of softies so far. I'll need more time to make a good judgment about these, but one thing is for sure, they did bring the temp up during the worst of the cold spell. I can't help but wonder if I had a stove capable of burning more pellets and rated for higher btu output, that then I would be satisfied with the less expensive MWP blend for all my heating needs. When I got my stove, it was about all that was available, and I was not well informed. This forum has done a lot to educate me. My son bought a big Englander used and he is very happy with it.Which MWP's don't do it? The softies or both?
