Hopefully ment stoker.I am in agreement on the inadvisability of trying this....what brought it to mind for me was in Kijiji a few months ago someone had posted an ad for anthracite rice coal and specifically mentioned "suitable for pellet stoves".....go figure!!
*Think use coal fire, to MELT steel, we haven't tried melting steel, with pellets....yet
LOL. Yeah, OK, I got the point the first time. Not advisable, check. Melted stove, check. Pets burned to a cinder, check. Denied insurance claim, check... check... check.After I hit post I flashed the thought of the Fukushima disaster but on a smaller scale.
Still looking. A local dealer is supposed to be getting a delivery this week. We'll see...So were you able to find more pellets, rkbaguy?
A possibility. I'd need to find someone to split it with. Thanks for the suggestion!Woodpellets.com will have 3tons of CleanFire to your door in 14days for $1,013.70. Unfortunately you can't buy less, but it's something.
Nope. Wasn't me. Leaving aside the couple flippant posts, the other more lucid replies convinced me that coal wasn't an option, and helped me understand the underlying reason why.Looks like the OP didn't like the answers here so he, or someone else from the forum, went looking for better answers
No, I didn't think it was you because of the stove referenced but it made me wonder.Nope. Wasn't me. Leaving aside the couple flippant posts, the other more lucid replies convinced me that coal wasn't an option, and helped me understand the underlying reason why.
Letting the ash build up too close to the grate is a sure way of cracking your grates. Other than that, they should last longer than that unless you were overfiring the stove or the castings were really sheeety.Coal gets hot enough to crack cast iron. I went thru about 1 grate a year before i changed my coal source. Also an volume of coal burning about 6"x4" and 1 inch deep ,about 24 Cubic inches can heat my poorly insulated 3000 Sq ft house to 75 degrees when its ZERO outside. Ill say it puts out more heat than wood.
Coal was clinkering blocking some of the air holes in the grate leading to uneven heat in the grate. Not really possible to over fire my stove. I changed coal and problem solved.Letting the ash build up too close to the grate is a sure way of cracking your grates. Other than that, they should last longer than that unless you were overfiring the stove or the castings were really sheeety.
Sounds like you have a stoker.Coal was clinkering blocking some of the air holes in the grate leading to uneven heat in the grate. Not really possible to over fire my stove. I changed coal and problem solved.
