Can someone recommend a brand and place to get clear (not red) hi temp rtv silicone sealant for sealing pelletvent duravent venting? I would like to get a caulking tube rather than a smaller hand tube. All the local places I have called seem to only carry red and don't seem to know about clear though people here have talked about it.
Does the temperature really matter? That is, 500 vs 600 or whatever, obviously you'd need a minimum.
This is for a retrofit BTW, we moved into a house with an old thompson-thelin pellet stove (1987 vintage) and I realized (after smelling vent gases easily when using it) that the original owners had used B type gas venting with no sealant! I'm not sure they had ever cleaned out the manifold after I opened up the cleanout and 3-4+ cups of ash just fell out!
After reading a lot on this forum I've decided to use the old original "multiple 90-degree turns, 1 foot rise (with vertical cap), horizontal out then up venting" holes to put in ducting for outside air since the hole is already there.
Any help is appreciated.
thanks,
Kevin
thanks,
Kevin
