martyinmi said:
heaterman said:
ihookem said:
Singedeyebrows, you can also throw in a dead calf and some garbage if ya want. Anyway, OP has a nice CB 5036. The unit is huge. I wonder out loud why no one uses storage a CB 5036. Run it wide open with 1,000 gal of storage. No idle time and run it hot. Should bring up efficiency.
While it's true that storage might help out the efficiency a tad for any boiler, there are a lot more things that enter the equation than merely not idling your burner. It's difficult to achieve any decent numbers when the stack temps from the boiler are running 600-800*+ like they do on a typical OWB of any kind.
Why would you type a statement like this without putting any thought or research into it first hand? Are you trying to convince people that ALL OWB's are close to 0% efficiency?
An 800* burn chamber with a 800* stack temperature would translate into close to 0%, right? Please enlighten us, Great One!
With all due respect, Heaterman knows exceedingly more than most here or anywhere else regarding the subject.
The data is out there regarding efficiencies(by ind labs, not bought by the tester), but basic Laws of Thermodynamics and pyrolysis are the factoring element.
Regarding OWB stack temps...there is a HUGE difference in PM Opt250 stack temps and average OWBS, but I can tell you I have seen "fried" flue pipe on OWBs(namely my brother in law's) and that needs some serious stack temps and the occasional fire.
ON the OP's subject, I think in the end everyone's situation is varying on personal criteria/preferences and individual parameters of install.
Specifically:
a) the Portage and Main Opt250 (IMHO) stands heads and shoulders above all OWBs( stand alone, no storage)gassers. I extensively researched it and was thoroughly impressed and was seriously, very seriously considering it.
b)The Garn is a beast all in it's own class, but it is not an outdoor unit in the true sense of the word and was sold on it.
In my case, in the end I could not run Underground lines for a couple of serious reasons and the expense of a Shed was also prohibitive.
So both these options were factually eliminated, much to my dismay.
c) Indoor Gassers, need some more "diplomacy" in handling, no doubt, but I have thus far found my selection to be VERY EASY to operate with significantly less wood than anticipated and the way I have set up my wood supply(still altering my supply line), is no problem. Cleaning wise...very easy thus far and every 3 weeks or so.
I was never going to throw "bull chunks" of logs in there, even with the P&M, since there it is not recommended as well.
My splits vary for 18"-20" iin length and from 4"-7" width at bark and MC 10-20%.
My brother in law runs an OWB(not a cheap brand) and burns same year splits(12" width) and goes through 11-13 cords a year, with 3-5 times a day feeds(he heats 2,800sq ft with average glass, HW baseboard & DHW.
I heat 2,950 sq ft with lots of tall glass(All radiant & DHW) and looks like 5-6 cords for the year(10-1-11 to date 2.75 cords).
I fire:15f and below twice a day(70% firebox full- 6.5 cb ft) and above 15f once a day or above 25f every 36 hours or so.
Big difference.
His system cost was 13,000, 4 years ago(he has replaced the flue pipe, gaskets and grate once already at an additional cost) and the door is going now.
My system cost me 20,000 this summer(thank God for HELOC). We will see what the future expense will be, but I expect a much longer life based on others' documented experiences form indoor boilers..
So like I said earlier, it is a personal choice based on individual criteria , so "better than" is not always equivalent across the board.
What is key though is the efficiency and scientific principles inherent in the unit of choice. Shorts cuts and assumption in that facet of selection are not wise in my estimate. Ie, for me at least, a boiler that sits outside rusting and rotting and returns a life span of 6-8 years on the investment is far outperformed financially by a unit that will last upwards of 10-12 years. Prorating the Oil/LP future increases in original purchase price only exacerbates said point.
To each his own, but in closing and to come full circle, I think Heatermans' statements are consistently in the upper echelon of "factuality".
Best Regards.
Scott
