Mark Fellows said:freeburn said:With a pellet stove (unlike a wood stove), very little cast iron actually heats up, it's mostly in the heat exchanger and the surfaces around the heat exchanger. So it's pretty much all about looks. That's why we have it, and the heat helps a little too. What do you need an exhaust sensor for other than to get covered in ash and not work properly. That's why the settings are there on the outside of the stove. You can always hook up your stove to a thermostat, be it programmable, or the cheap slider. Plug and play!
That's a very good point if you are just thinking about radiant heat. However, my stove has cast iron heat exchangers which do provide more steady heat exchange than steel.
Mark![]()
I`m not convinced cast is better than sheet steel. From what I can gather they are very close even when used as randiant heaters as in (wood stoves).
Cast iron does hold heat longer but takes longer to heat up. I believe heat exchangers in most heating systems are sheet steel vs cast iron for reason of more efficient / quicker heat transfer. However if you can find info contrary to above, I`d be interested in reading it.
I'm getting the XXV installed on Oct 22nd. I eventually decided to go with Harman with the best dealer I've dealt with... It was between the XXV and P43. It ended up being $700 more for the XXV but I didn't want to look back years from now and regret not getting the stove that I liked the best to save 700 Bucks.
