Hello,
Long time reader, first time poster. This website is a wealth of knowledge and appreciate the supporters of this forum.
Anyhow, bought a circa 1979 home to remodel, and just now getting to the fireplace after a year (it was way down the remodel list).
I was going to install a SS liner in my fireplace that had a old Buck 27000 slammer install, certainly a DIY job I could handle, but with my work as a test engineer, often being TDY (like most of this winter), I was not going to get it done this winter season.
Needless to say, that Buck beast was a creosote machine, and the older woman that lived here certainly never run it hot enough, which did not help the situation. So I knew I would need an insert. (I know the Buck is not the most efficient heat generating machine, but for the time being, it will suffice until we can step up.)
Given my predicament , decided to get some estimates for a liner insert.
One company quoted $1600 for the liner and poured insulation. Given the costs to connect to a Buck (150 for the adapter), thought that was a good deal.
Here comes the good part, the gentlemen finished the work last week with 10" SS liner, but only the flue. Crawled in it and look up, no connection and no work on the masonry to accept the liner. It starts at the flue, just above the chamber and terminated at cap with poured insulation. Maybe he thought I would not check out the install when I got back in town.
Called them up, state they do this all the time. "Let us still run it as an open fireplace". Now why in the world am I going to remove that beast, if not to replace it? My comment is it has not solved the problem, that it is still fundamentally a slammer install, just with a better flue. I think this is a bit disingenuous, who would quote or ask for a partial liner? Their quote has no mention of it being partial.
They now want $400 more to finish the connection, which will now require a reducer to 8" for a buck adapter. JOY!
Luckily, I have not paid for the services rendered, as I believe 1600 for services rendered is a bit high, even with 10" SS. I believe in customer satisfaction, just thank the Lord my wife did not pay until I reviewed it!
I've taken some pictures that I will attempt to add to show the inner install, but disappointing to say the least.
I believe heavily in doing the work yourself if you want it done right, go out on a limb for one item, get burned.....excuse the pun.
Thanks all for letting me vent.
Merry Christmas
Merry Christmas
