Yes it does who else would do itGood question, who would you call for an estimate. Does this type of work fall under chimney sweep.
Any one know.
Any one know.
Nope not if the chimney is a good candidate for removal. It really doesnt take much pounding at all.I'm just guessing here from a construction standpoint, wouldn't removing the clay liner severely weaken a chimney, all that pounding to remove it.
Elisurfer4, it wouldn't hurt to call some chimney sweeps and see what they charge, at least you can report back and let us know for our own knowledge even if that's not the way you go.
I’ve got a bout a cord on hand right now.. but that’s definitely a thought. I just feel like I’m SO close to being set up considering the stove is in my car currently haha, but I was not anticipating the hang up on the liner end.If the coin isn't there this winter for your install then save up for an install before next burn season and in the mean time process as much firewood as you can. A beautiful new stove is only an ornament if you don't have the fuel to put in it.
Oval insulated duraliner will fit those dimensions as described. It comes in solid and flexible sections for getting through the damper. The flex sections will need a insulation wrap. And various oval to round adaptors. I've used it on my own insert and it's high quality and works flawlessly. It's also handy if your chimney as short as you can extend out the top up to a length(no exposed connections). It's not cheap but it's high quality(IMO) insulated pipe, offering great performance and safety.
View attachment 220267 View attachment 220268 View attachment 220269 View attachment 220270
That’s beautiful. What a view you got goin there too! Do you know if there is a more simple cap option for the rigid duraliner as I’m working with 25’ and don’t need to extend and I know that part is pricier.I'm not sure now where or if this is the thread I recently posted a cap pic so here it is.
The duraliner is obviously the one on the left.
Ahh. I believe all the caps are meant to be variable in height in regards to the rigid components chosen.
For the duraliner I see only the extenda cap and the twist lock cap. I think the extenda cap comes in oval or round and the twist lock cap is round only.
You really need to get up there and make sure your clay liners are straight with no major offsets before commiting to rigid. It doesnt take much of an offset to make a rigid install go bad.alrighty guys... think I'm gonna go for the duraliner setup. I am going to call around and see if I can get any pro's around town to do the install, but so far it seems no one has even heard of duraliner pre-insulated rigid oval(we're in central VA)... Ideally, I would be able to do the install myself, but I think it's pretty clear here I'm over my head on that one. I actually called my insurance company but they wouldn't budge on making this into a claimHere goes nothin.
Yes but at that dimension the flue still needs to be pretty straight.duravent oval ridged is only 4 3/4" x 7 3/4". But certainly have a look and re-measure before shelling out.
Yeah that’s a good point. Shortly after posting my above declaration I actually called a local company that was very educated and down to earth and they basically have volunteered to come take a free estimate and said if they can fit insulated oval down, they’ll charge me between $800-$1000 for full install.. now that would be a dealYou really need to get up there and make sure your clay liners are straight with no major offsets before commiting to rigid. It doesnt take much of an offset to make a rigid install go bad.
