Echo 490. Brand new. Everything adjusted properly.
Ive used chainsaws in the past but not for a while so i dont remember if this is normal or not.
Im not pressing down too hard, just letting the chain do the work. Initially touching the chain (while running) to the log, the chain spins fine and cuts well.
Then randomly (a inch down or so) the chain will just stop. ill have to lift the saw up slightly and then it will start again.
again, havent used one in a while. i thought the engine is strong enough to simply blast through anything. is this a safety feature on chainsaws?
Thoughts and thanks.. ( i love this forum)
Man, you've gotten some great advice. I'll be checking out my own machines based on what I've read. Here's a new angle nobody's brought up yet.
Are you keeping the saw completely horizontal while you cut? I could see a saw stopping under those conditions. All the manuals seem to say "
cut at a 45 degree angle". When I'm bucking something big (24"+), I like to start on the opposite side (of course) and cut until the saw is nearly vertical. Then pull the saw out and start again 4-5" back from the cut with the spike, and then rotate the saw back into the cut as if it were on a hinge.
Just keep repeating. That way, I'm always cutting at some kind of angle and the saw likes that A LOT better than dolefully trudging through a horizontal cut.
I reserve a horizontal cut only for the last two inches before going completely through, assuming that the log is on the ground. And of course, never touch the dirt, a rock or a nail or it's game-over.
Seriously, get yourself a hand file for your chain. But first buy a spare chain of any variety. Give filing a shot and see if the results change. If they don't, try the new chain. But you're going to need to learn how to sharpen the thing somehow, and it might as well be on your property at the end of a day before your next day of work, and not having to drive to drop off and pick up. Plus remove and reinstall.
My gold standard is to hand file after
every day of hard work. Less effort, less fuel, better results, more satisfaction.
With a sharp chain and a machine that runs, I've had no problems cutting 30" oak rounds with a 40cc saw with a 16" bar, narrow kerf, all day long.
I think the LAST thing any saw wants to do is run 100% horizontal cuts.
I wondered if you were cutting Hackberry. That stuff is so darn stringy it's on my list of "This better be an emergency" before I take it. ;-) But I can't identify what you're cutting.
Best of luck. There is a solution. You will find it. It takes time.
