Home Depot rents a 20" saw (I think it's a rebranded Dolmar) that people rave about. Maybe just renting the saw is an option.
Craiglist is a good spot to look... 2 Brand New Husqvarna 460 Ranchers w/ 20" Bar, went up for $250 today. Both new and never used.
I have a 455 Rancher and for general firewood cutting, its all you need. I recently took off the 20" and put a 16" B & C on it. Big difference. Made a good saw, much better...
I also own a 036 Stihl and MS 460. They are also great (read: GREAT! !!) saws. But they are in a different league.
For $250 you can find a nice running 55 cc + or - w/ 18"-20" bar for $250. And not have to "settle". That will pull in a nice saw....
... The first use this saw will see is going to be cutting up a 100' Tulip tree to give you an idea. It's probably about 5-6' in diameter at the base. ....
) and buy a used 70+cc saw. If that trunk really is 5'+ you're looking for a 28" bar, minimum, 32"-36" would be better. You should be able to buy any saw in this class, get your work done, and re-sell for the same price if you take care of the machine and keep it cleaned up. Easiest to sell if it says Stihl or Husqvarna on the side. Hell you could buy a new saw and maybe only take a $150-$200 hit (on a $800 - $1000 saw) if the saw looked new when you were done. Unless you buy a new saw, you most likely will be buying a big bar for whatever you pick up.I've got a ms250 and was initially disappointed with the performance until I switched to a more aggressive chain. It made 2x the difference. At first I figured it was the smaller CC size but I'm glad I didn't go for a "do it all" saw in the middle. The 250 is light and easily controllable for me. I'm not cutting for a living so a little more of my time is not that valuable.
Chaps are about $60. Gloves, helmet w/ face shield, gloves, wedges etc.
Good luck getting through a 5' round with 100 bucks.
I'm guessing it was 26RSC-68 for the 18" bar. Anything that fits the saw/bar and says RSC for the type should do nicely.Im thinking of getting that saw, what chain did you switch to that made a difference?
Unfortunately, you're about to expose my ignorance(don't look at me!).Im thinking of getting that saw, what chain did you switch to that made a difference?
Look at post #31. Stihl has made it easy. Just make sure your chain DOES NOT have a "3" after the description ex. RSC3 or RMC3 this is the safety chain. Safety chain will also have a green mark and packaging, you want Yellow.
Or just buy Oregon LGX in the right gauge and driver links configuration for your saw (should be marked on the bar).... I'm guessing .325 / 68 DL for an 18" bar.
They usually come around when it's 70+ in the house, 0 outside, and the heating bills are non-existant. Think about how many MS362's you could buy with all the money you save on oil/propane/NG! ;Having worked with big trees, both felling and blocking them up for firewood, this thread has been...interesting. $150 for a BlueMax chainsaw to address a 5' tulip poplar? Right.
It's simple: buy the right tools for the job or pay someone who has the tools to do it for you. The things that get cut from big trees are heavy, bulky, and dangerous.
Just finished blocking up a 36"dbh/80' tall cottonwood that I had taken down with a crane earlier this week. For the trunk pieces, 80cc/28" was enough, but the resulting rounds were still 250lbs+ and had to be quartered before I could carry them off or put them through the splitter. Rounds out of a 5' white oak from a few years back required a Bobcat to move and even then were a tipping load.
If you're going to only buy one saw, buy a 60cc-class saw. Buy a 16-18" bar for regular use, and a 24" bar with skip chain for occasional bigger cuts. This will cut 90% of what you will ever encounter. Skip the remaining 10% and call it good.
I AM NOT felling this tree. I am only cutting it for a friend after it's down. He generously offered me as much wood as I could take. I DO have experience using a chainsaw, but very limited. I am aware of how to use one safely including the recommended PPE. My questions only pertain to buying one because I don't know what factors go into owning one for the limited use it would see. Thanks for all the replies.
I found a 024AV Wood Boss, but I don't know anything about it and it's not on the Stihl site, so I'm guessing it's an older model. Can anyone give me the lowdown and specs on this one? The saw, a bunch of chain oil and a set of chaps for $200. Good deal? Thanks!
