Wish I was handy enough to make something cool out of it, almost too pretty to burn lolHa, that's the same way I got the cedar. My next-door neighbor had it laying around and didn't want it. Mixing it in with a denser hardwood is a good plan.
We've had a few such debates on this forum over the last decade, and the conclusion has been that this oft-repeated advice comes with a caveat. Here's the reasoning:Always thought to burn something sappy like cedar was considered "dangerous" if that's the main wood you're using.
Great idea thanks!Smells nice too. You could make 1/2" thick cedar hanging blocks to put inside of wool clothes hanging in the closet.
Ahh makes sense, thanks for the info!We've had a few such debates on this forum over the last decade, and the conclusion has been that this oft-repeated advice comes with a caveat. Here's the reasoning:
If properly dried, as a few have already stated, these woods can be burned as safely as any other. The trouble comes with the fact that, unlike most hardwoods, cedar and pine tend to also burn pretty well when they're wet. Thus, generations of burning this stuff while still wet has created the real danger of which you have likely heard since you were very young.
Creosote build-up is proportional to the amount of water condensing in your pipe, as you burn. Water droplets form on these particulates, and an excess of moisture will increase the amount which condense on the inside surface of your flue. If the wood is dry(er), more of those particulates are safely ejected from the chimney, before having such opportunity to condense on the pipe.
I know you have less choice of woods out west, but here we mostly just use cedar as sleepers under piles of logs. Between their short burn time and difficulty in splitting, they stack up pretty poorly among our available choices.I’ve burned cords of nothing but cedar. We get some big ones out west. Several feet across. I’d actually prefer pine because I find that there is more soot with cedar. Not tar and not particularly dangerous but an acceleration in normal brown buildup.
Still, hard to waste good fuel.
On the plus side, they do make good kindling, if you have the hydraulics to split them. And they last damn near forever, I have cedar fence posts marking one of my property lines that may predate my grandfather's birth.
Hm, I have to say that the smaller eastern red cedar I had here (max 6" dia) was easy to split (I did that because I needed it dry enough in one year.) I was actually happy with that. I am now curious to get my hands on a bigger tree to see if I can manageI know you have less choice of woods out west, but here we mostly just use cedar as sleepers under piles of logs. Between their short burn time and difficulty in splitting, they stack up pretty poorly among our available choices.
Thanks , yeah I decided to split a good portion of it as normal splits and then ill make some kindling on the side. Next thing in order is trying to find a stump lying around on the side of the road i can use to split on lolOur cedar is smaller down here, but it also has a shallow root system. It has spread so much and taken over so much land that it’s considered a native invasive. It’s harmful to the oak trees because it tends to get the rain water before it has time to make its way down to the deeper oak tap roots. We are clearing a lot of cedar away from oak trees because of that problem.
A lot of ours is pretty young and grows like scrubby bushes, so we have small pieces. At the same time we also can get knotty stumps that can’t be split. We had had one large stump sitting in our barn for a few years, and my husband just got around to noodling it the other week. It was already down to ten percent moisture, and we got ten large chunks out of it. This firewood rack normally stays outside on our deck, but I brought it in for a few days earlier in the month prior to an ice storm. I didn’t want our wood to get coated, and I didn’t want to have to make a trip over ice to get more wood. Our normal wood box was full of oak, so we used the small cedar to burn down coals, but the large chunks turned out to be some amazing firewood, and we used them for overnight burns.
@velocity1 , you mention splitting all your cedar into kindling. While it’s a fine choice, you could also consider leaving some of it fairly large. It should still season. Since it tends to season more quickly than large pieces of hardwood, you can leave it much bigger, just constrained by what fits reasonably in your stove.
I will say that I do have the same experience as @Highbeam that it tends to be sooty. When we burn cedar we see the smoke in the firebox more, but it gets burned up by the secondary combustion before it leaves the chimney. It can leave more brown film on our door corners, though. Your cat should do the same process of burning the smoke.
Enjoy it! A cord of cut wood already on your property and possibly already seasoned is a great thing!
