Lucky for you, Highbeam. This is more for all the non-BK / traditional cat stove owners out there.
I've been putting more thought into the situation, and it seems to me there are two ways to run a cat stove:
1. I have been getting the load charred and baked out enough to where exhaust temps hit 550F. Engage cat, get cat lit off, and turn down the stove for a nice controlled burn. 99% of the time this will prevent the load from ever getting going well enough to produce problematic rates of wood-gas production, but perhaps 1% of the time a shift in the load or other factors will cause it to out-gas so fast that your cat temp can skyrocket. Doing 300 - 400 loads per year in a stove means at least a few cat over-fires every year.
2. Burn out the load until there are simply not enough volatiles left to cause a cat overfire, when you turn it down. This has the disadvantages of shortening burn time, running the stove up hotter than you might otherwise want or need, and requiring you to stay in the house longer after a reload, but leaves almost no possibility of cat overfire after turning down the stove.
I've been doing version 1, but I'm going to spend the next several days experimenting with version 2.
