rich, post #6. The manual doesn't detail the heat exchanger area or how to clean the internal exhaust pathways beyond removing the blower. I generally use dryer lint brush and tube on shop vac attachment with the stove ash dead out (drywall bag). The leaf blower trick might be helpful depending on venting configuration.
Fly By Night, if your friend tries the leaf blower trick, she needs to disconnect the vacuum switch tubing so it will not damage the switch and stove must be off and cool. https://www.hearth.com/talk/threads/help-with-leafblower-trick-with-pics.74539/
You can also you tube for videos. If she's rural, should be OK but in town/city neighbours might get upset as it shoots out a stream of fly ash.
Switch on the hopper lid not working properly? Any other ideas? Will only fill the pot in initial startup and then auger stops feeding.
saved me a pic lakegirl, was gonna take a pic on my serenity tomorrow when I got to work
Post #26 of this thread shows the vacuum switch
https://www.hearth.com/talk/threads/my-journey-with-a-castle-serenity-pellet-stove.142222/page-2
Thanks again Lake Girl...I am assuming the vacuum switch is the white round unit that looks like a smoke detector with a rubber hose attached to it? Anybody know what holds it on, just screws or bolted?Post #26 of this thread shows the vacuum switch
The other sensor is just a spare back up.
I keep hearing good things about those stoves. I am looking to install a second stove in the basement and if I can find a Serenity up here I will jump at it.
