Be careful. If he's getting wood from this guy that's as dry as he says it is, steering him towards cheaper, less seasoned wood in midwinter may not be doing him a favor. Wood as dry as he says this is is literally impossible to buy in most places for any amount of money.Damien where are you at in the Burgh exactly, well, I don't want your address or anything. But I hate to see nice folks get ripped off maybe I can help?
We are pm'ingMaybe take the local wood supplier stuff to a Conversation between the two of you PA-er's. Let this thread continue to focus on getting the OP's stove up and running.
If you have a hitch on the back of your car, Uhaul can be your friend. They also rent trucks that can take the weight of the wood.
At the risk of sounding like a jerk, when ever you modify your stove and it then does not work, remove the modification and try again.Regarding the stove Kaowool out and the stove had no problem starting so I believe the problem is solved
Not sounding like a jerk at all, simply stating the obvious. These stoves are made to spec by the manufacturers. If one mods it, you can't blame the manufacturer where they void the warranty. It is for instances like this that they must impose these stipulations, that all of us are held up to.At the risk of sounding like a jerk, when ever you modify your stove and it then does not work, remove the modification and try again.
I had been thinking about that the other a friend of mine cut down lots of tree on his property he told me I could take whater I wanted.
Regarding the stove Kaowool out and the stove had no problem starting so I believe the problem is solved.
The manufacturer, CFM Corp, went bankrupt with VC. Spare parts are available through Century Heating, but they aren't the same company. If they follow the VC model, there is no warranty.
Maybe rent one for $19.99/day?Unfortunately I do not have a truck
