Well hey yourself. Haven't run the Windhager in a couple years because of what I thought oil prices were, but they're going up. It's ready to go, though. The six tons of pellets in the basement still seem good-it's a dry basement. That reminds me: I have to clean and service the oil boiler and clean out the wood insert's flue.Well hey Velvet! How ya doin? Windhager still good?
Just checked. $200/ton here from the pellet factory in TN. I'll burn a little more than you Mr GB...... in southern TN..... I guarantee my 170 YO house is vastly less efficient than yours in Wisconsin. If my old place was up in your woods, I'd be burning 12 tons and be thankful to be burning pellets! Cheers
Would love to see some pics when possible.Hello all!
Apologies for not updating you all sooner. I am hoping to take some photos for everyone but we had the MeSys boiler installed back in mid-January.
The reason the 20Kw Mesys boiler is rated at 77% efficiency is the way the EPA forces the rating to be at low fire, (mostly). The efficiency at nominal output is actually 80.4%. This is lab confirmed, NOT manufacturer. Their larger units are higher also. 83.7%for the 32Kw unit and 86+% for the 56Kw model.You’re definitely not wrong there. The contender from MEsys hits 77% and the Windhagen is even a bit lower than that at around 65% (not looking at exact numbers). Pretty wild that some are 50% and that’s considered efficient at all....
I'll add it's worth noting all these efficiencies were done without thermal storage. I've read positives and negatives on the topic but what's interesting is MEsys is the only company who really doesn't suggest thermal storage. The companies that do suggest thermal storage seem to be the ones with lower efficiency ratings which makes me wonder how all of that comes into play.
Post a picture of your igniter.Hi All, I'm new to this forum and Hearth. I wanted to reach out and get some opinions from ya'll. I had a Kedel boiler installed in 2016. I knew there was going to be a learning curve with it but thought it would settle in and eventually pay for itself. I've had all kinds of issues with it over the years. My local guys who installed and service the boiler have been out here a zillion times this winter. They are just as frustrated with these units as I am. The biggest issue I've had over the years is the ignitors failing. There have been other issues as well. I'm exhausted with not having heat in the dead of winter (Christmas morning, 3 degrees out, no heat). I have zero interest in going back to oil heat or some other fossil fuel. What kind of boiler do you have, and what has your experience been like? I'd really appreciate some honest appraisals. I may just end up replacing this unit.
I purchased a Maxim in January. This was my first OWB. I've been very happy with it. It's ability to go idle and restart itself has worked very well. Mine heats a 7000sqft house and I've never had it set to run over 65% of it's max capacity. I would say it holds 1.5-2 tons worth of pellet ash. So doesn't need emptied very often. Keep in mind the mindset of the 6048 and Maxim are different. 6048 you want hot burns. The maxim you want it running in medium (40-50%) as it's the most efficient. Two things I would recommend.Looking for information on central boiler maxim 225 pellet boiler in looking to buy one to replace my central boiler 6048 wood boiler
Thanks how many tons of pellet s do you go throughI purchased a Maxim in January. This was my first OWB. I've been very happy with it. It's ability to go idle and restart itself has worked very well. Mine heats a 7000sqft house and I've never had it set to run over 65% of it's max capacity. I would say it holds 1.5-2 tons worth of pellet ash. So doesn't need emptied very often. Keep in mind the mindset of the 6048 and Maxim are different. 6048 you want hot burns. The maxim you want it running in medium (40-50%) as it's the most efficient. Two things I would recommend.
One, be most efficient with everything. Use the best insulated lines, insulate your lines inside where you would normally not insulate them. You really want to be able to extend your idle times out as much as possible for the shoulder season. Also you will notice any wasted heat, compared to your 6048, as you are putting in bags instead of just cutting and throwing more wood in.
Second, familiarize yourself with the back burn set up on the maxim. By back burn I'm talking about when the maxim goes idle, the string of pellets in the feed auger can smolder and burn back through the auger. CB has done a really good job at implementing protections for this. These protections weren't there in the early years of the maxim and people had fires in the hopper. I have had back burns happen, but the temperature switch a few inches into the auger has always triggered the first safety protocol which has always handled and recovered automatically. If I weren't watching closely or monitoring it with the wifi module, I wouldn't even know it happened. That's how well my Maxim has handled back burns. But there are things you can do to minimize them like turning on "clean out" mode for a few minutes each week. Also, the back burn safety protocols require electric to the unit to function. So just know if you lose power, you'll want to clean out the burn chamber so it doesn't smolder back into the auger.
Overall I've been very happy. Since you have a 6048, if you don't have the thermopex lines, get them replaced. I have the additional 48 bushel hopper which works flawlessly. Other then having to load more pellets into the hopper, I could get away with ignoring the Maxim for many weeks. But I don't as I enjoy the process.
2 for January, 1.8 for February, and 0.9 for March. I had some areas (attic) that were not insulated and just recently got that fixed. So my usage should be lower next season.
im in northern Ontario and going through 60 stove cords of unseasoned wood , so I’m trying to figure out how much pellets I’m going to use and a pain in the butt I’m guessing it’s going to be 30 tons , if anyone has a clue and can help ou it would be great ive looked at the conversion tables an still can’t get it2 for January, 1.8 for February, and 0.9 for March. I had some areas (attic) that were not insulated and just recently got that fixed. So my usage should be lower next season.
At roughly $200US per ton and going up * 30 tons.im in northern Ontario and going through 60 stove cords of unseasoned wood , so I’m trying to figure out how much pellets I’m going to use and a pain in the butt I’m guessing it’s going to be 30 tons , if anyone has a clue and can help ou it would be great ive looked at the conversion tables an still can’t get it
