Hi all, I’m hoping to get some advice. I purchased a 2 floor, 2,400sqft home last fall with a hearthstone Clydesdale 8490 insert. The owner told me he always dreamed of having a brick fireplace so he started with that and decided he didn’t want it after all and had the insert put in. They put a pipe up the chimney with what I’m guessing is just a single walled flex pipe? As far as a cap I’d barely call it a cap. It has no damper or mesh to stop critters.
After trying out the fireplace I didn’t feel I was getting the heat out of the unit I was expecting plus the fan was clanging. I replaced the fans and still wasn’t impressed. So I spoke with someone and they said seal up around the unit well and get another fan behind the unit and slide the insert forward a little bit to maximize the heat off the back of the unit. This helped a lot get more heat into the home but still doesn’t seem great. But when doing this I created a new problem. When a fire isn’t going the fan is believe is pulling smoke from the fireplace and setting off the carbon monoxide detectors. Plus this thing burns wood like crazy in my eyes. And finally the last issue the last home owner warned me that he’s had backdraft or down draft issues that push smoke back into the house. I didn’t experience this until the other night. It was warm during the day and at night temps dropped fast. I’m not sure what happened but everything started off great next thing I knew I had smoke coming in. And the smoke was coming in from all around the insert. Back, bottom, top. I believe these units are built in multiple pieces but it’s far from airtight. Plus side is I know the door seal I installed last season is good because that was the only place smoke wasn’t going from.
So after all that info here’s the questions.
1. Do I just replace the unit for something newer? Higher btu, more efficient and if so what would you recommend?
2. Do I install a chimney exhaust fan to help with downdraft or something with a damper?
3. Should I just fix the unit and what should I do to fix it?
4. Finally, Should I get a life insurance policy asap?
If you’ve made it this far reading and haven’t said omg this guys a lost cause I say thank you.
