I've been a mechanic over 20 years, and have had my run ins with troubleshooting problems that have kicked my butt for days. I still, to this day, get a warm fuzzy when I see or find something like that.
I think we may have just fixed it! The stove started going out when they were putting the side panels back up and they realized that the wires on the side going up to the hopper were getting pinched. Has anyone ever had this happen?
Before they found the pinched wire they did some kind of pressure test and it read normal.
No. But I've noticed those wires also. I bet it's the ones for the hopper switch and they are grounding out on the metal. That would explain the auger stopping which would stop pellets dropping , the fire would go out and then you would get cold.
Mine look very tight also and have no problem so I'd wait until I changed those out before I declared victory. If yours are as tight as mine, check the connection to the hopper switch, maybe a bad connection at the switch (or bad switch itself) and not at the actual point where the wires go into the hopper.
i just want to add info to this...after one season of owning a cab50.. had to replace my door gasket and i did the glass gasket as well was leaking at the door seal ...after doing this, my glass stays cleaner longer now... from day one i think it was a bad seal as i would almost have to clean the glass everyday...i never bothered with warranty... i went online searched and found what i needed and bought at my local home hardware ...the original is stuck in with hi-temp rtv ....so i got a tube of this too....very easy to do..
3/4 rope kit from imperial for the door seal-GA0191 3/4" Fiberglass Gasket Rope Kit
and new glass gasket kit-GA0009 5/8" x 1/8" - 8' Window Channel Tape (white)
Permatex 81160 High-Temp Red RTV Silicone Gasket, 3 oz
also, after reading more....my stove heats my house, my only source/backup is electric....my dealer told me to keep my fan switch on high. clean after every 5 bag. pipes after 25 bags...
yep.thats the ones.. the door seal kit i have about 2 feet left. and the window seal only goes on the 2 sides, not all the way around..so i have lots of that left too...and the tube of hi-heat red silicone i use on my exhaust pipe every time i clean it.so i have lots left as well..dealer said every 25 bags for chimney cleaning..with the new door seal kit i did notice the door seals tighter now to..guess cause it needs to squish the gasket now .....
