I'm very familiar with fire and have used plenty of wood stoves in my day but have never owned one. I intend to operate my stove 24/7 in hopes that it will be very close to a primary heat source. My wife and I work full time and due to our schedules I'm not sure we can accomplish a 24/7 burn. The stove will be a Napoleon 1400 (2.25cuft firebox) and the house is 1500sqft. Its a two story colonial and is fairly well insulated. Based around our current work schedule here is what we will try to do (assuming it is very cold outside):
5:45am - rake coals from previous nights low-burn. Fill firebox and adjust to high burn.
6:30am - set to low-burn and go to work.
4:30pm - rake coals from morning low-burn. Add wood and adjust to high burn.
5:30pm - set to medium burn. Add wood as necessary.
10:30pm - fill firebox and set to low-burn. Go to bed.
As you can see there is 8-10 hour interval while we are away at work or sleeping. Will this type of schedule work with 24/7 burning? Will there be enough coals to keep things going? Will I experience any excessive creosote build-up? We don't mind the house cooling down while we are at work or sleeping. The thermostat will be set to 55 and furnace will kick on if necessary.
Thanks in advance!
Thanks in advance!
