M
MasterMech
Guest
There's an 038 Super that just came in that's just itchin to be fed some logs too.... (but that one isn't mine)You have two 460's and no wood to cut?
That's just selfish.
Or better yet, grab the saw and come on out. I gotz food and beverage.
OK so a quick update for everybody. The saw is a runner, sort of. I'm not happy with the way it's running. I think the carburetor is losing it's adjustment since the limiter tabs have been tampered with and there are no springs on the needles so nothing to keep them from vibrating in or out. I can get it running great and then after a couple minutes it's all wacky again and the needles (particularly the L needle) seem to move on their own. Hard to tell since they are buried in there pretty good with these saws.
I also had to monkey with the high voltage lead for the ignition system as it wasn't carrying spark to the plug. Got that solved for now, I will most likely wind up replacing that lead in the future.
After playing with the position of the clutch side crankshaft seal, I was able to get it to seal up perfectly. (Just tapped it in the bearing a bit to give some clearance from the snap ring groove.) The saw holds pressure and vacuum perfectly and pumps out 167 psi on the compression tester.
The first shortcoming of the aftermarket kit has revealed itself already. The damned decomp valve pops out after every pull! I personally don't need it but sheesh.
And I desperately need to get a test log to saw on here. I have virtually no saw-able wood to play with now unless I start cutting splits in half!
Can you start the saw without the decompression button?
There's no way I could on my 460. I tried it once and I had to pull on it so hard that I snapped the starter rope.
I am thinking that those adjustment screw springs are a must.
Both of these will pull over quite decently without the decomp button. I don't even bother with it for a warm/hot re-start.
The elasto-start starter handles make a big difference. Enough so that I have them on everything except my MS230, which is an EZ2Start model anyways.
Dunno if the previous owner did some work on my saw, pretty sure it's stock but it sits just under 200psi compression.
This carb isn't designed for those springs, so I'm going to get new limiter caps for it. I wonder if blue loctite would keep it running for now?
Hi Master
try preasuring it up in a bucket of water,fish tank works nice you can see everything.
Thomas
There is NO pressure loss from a crankcase pressure test. (even after 2-3 minutes. Also holds vacuum just as well.) I doubt dunking it will tell me anything I don't already know. The issue seems to rear it's head when the saw is hot and as I stated before, there's just too much time involved in prepping the saw for a pressure test to get a reading while it's hot. Going to be a little bit of trial and error from here I think.
You know alot more than me but wont a vaccum leak make it run lean? If its only at temp I would think Ignition or someting along that line
JIM
Still looks good through the muffler and spark plug hole. Pulls awesome (160+ psi) compression.Since it's an aftermarket kit have you check the p&c for scoring?
I would say it's somewhat "normal" What happens it it will settle in to an idle, break up and die. Requires the throttle cracked to restart. When I get more time, I'm going to swap carbs just to put that one to bed. I'm taking the "good" saw out to play tomorrow so I don't want to tear it apart just yet.Do the RPM's drop quickly coming out of WOT?
I would say it's somewhat "normal" What happens it it will settle in to an idle, break up and die. Requires the throttle cracked to restart. When I get more time, I'm going to swap carbs just to put that one to bed. I'm taking the "good" saw out to play tomorrow so I don't want to tear it apart just yet.![]()
The part that gets me is that it leak tests perfectly. So if the carb swap reveals nothing, then I'm going to have to resort to replacing things one at a time I think.Sounds more "carby" than "air-leaky" to me. Never dealt with it on a saw, but have on a couple 2-stroke dirtbikes. Both had a leak at the jug gasket and would run and idle fine...but the RPMs would shoot to the moon and stay very high after WOT. If it is dropping pretty normal but won't idle that doesn't scream air leak to me...but I'm not an expert and have been wrong before.
