150K is not a low cost build for that sixe IMHO. I built 3200 sqft for <150K material only, all my labor. You can double frame 2x4 walls on a 2x8 plate and blow in the walls, very low thermal loss. Consider Roxul if you have not, I'll never use fiberglass again! Remember sheet goods are the only way to effectively seal a house (plastic rolls, sheets of foam taped at joints etc.) Check out GreenBuilder and BuildItSolar they both have great reading on how to properly seal/build building envelopes and how to vent, the vast majority of builders/tradespeople have no clue how to properly do thiese things. Also there are great tips on how to save on framing costs and economy use of lumber elsewhere. You can only do these steps once, many mistakes have/are still, made and tons of research has been done on this subject................read up!
You can change that kitchen/bathroom many times, but the building envelope and structure are only once, spend the money where it pays you back every year.
TS
TS
temps. The multi split's output really drops off when real cold temps set in and efficiency goes down as well.
