NATE379 said:
Well thought about it, but wanted to test em out in the field to make sure they work before its truly permanent. I wasnt sure about welding through the zinc plating, and If I need another bolt or two I could also just drill a hole or two a little further in. For one thing the latches ended up a little lower than I wanted, the pin barely comes up through the plate, I want to make sure under weight there isnt enough flex that it might pull through before I do anything else.
Jags said:
Looking good. And the weld next to the locking mechanism is pretty sharp. ;-)
Thanks, I wish they were all that good!
Ok well this should [finally] finish up the construction portion of the wagon...
Thats all the decking I bought, and I should have barely enough pt plywood for the rest. I didnt plant on doing the gate out of 5/4 decking but I had just perfectly the right amount of cut off ends left over the right size, and I figured the tailgate could take some weight since it might be used as a ramp to roll up the big rounds. Axle is just mocked up, not attached yet...
Here are some brackets I made to mount the axle to the frame.
And thats how the axle goes into the brackets and bolts to the frame. It can slide anywhere from center to all the way back, just need another pair of holes to bolt it. Going to see how it does where it is first, I didnt go all the way back but further back than most since I think the extra tongue weight will aid in traction on the 2wd tractor. If its too much tongue weight loaded, I'll move it up.
And now for the mostly finished product:
I ran out of some bolts, but other than that the only thing that remains is to clean it up and paint it.
I couldnt find a load rating on those tires, but they do say only 2 ply. Same tires thats on one of my cubs thats hauled quite a lot of weight around, so hopefully good enough for now. But they are old tires so probably replace them at some point. They are wider than most small wagon tires, so should be good in mud and snow I hope. It does make the total width really wide though.
Thanks everyone for the help and support. I'll get to test it out soon, either this Sunday or next weekend. I'm pretty excited I think it turned out well, even though it took a lot more man hours out in the cold than I thought it would (and I think its why I got sick a few days ago), I'm glad its finally done.
