Building a massive hearth for a wood stove.
That's not near as old as I thought, good job with the insulation! I estimate 3.5 - 4 cords for that size, insulation, and location. On a side note, did you air seal?
Rhonemas said:
In upstate NY, by sounds your house is old, my guess you need 5 cords for the winter. You have about half. I find January and February are usually the coldest months, I'd try to maximize the wood use for then.
Save a weeks supply for emergency. You don't want to risk a storm coming through late knocking out power for several days and you've run out of wood.
I'll second that usage. Of course it's a guess. I used around 4.something cords last year. I have about 12 in the yard now.
About 2 cords of that is crappy wood (pine, poplar, sumac), so I'm sort of counting it as 11. I almost feel like I need about 3-4 more, but I feel pretty comfortable with the stock pile now.
In reading comments from others on the forum, the general thinking is that when your S.O. starts thinking your obsessed, you only need a few more cords. :cheese:
Gnawrot:
Asking how long 2.7 cords of wood will last in a 40,000 BTU stove is akin to asking how many miles can you drive on 2.7 gallons of gasoline in a Ford F150.
Answer: It depends; i.e., how dry is the wood, do you burn hot or smolder, how many fires per day, is it a Phase II stove, what is the average fuel load, what indoor ambient temp are you comfortable and wanting, what (size area) are you trying to heat, etc., etc., etc.
Get my drift?
Aye,
Marty
PS: Having your own wood source is a very good thing and you are sure the envy of many.
Marty S said:
Gnawrot:
Get my drift?
Aye,
Marty
I don't have too many trees to cut. Remaining trees are tricky to cut (one can't drop them).
I would burn wood hot and the wood is dry.
Air seal? What do you mean by that? Vapor barrier or Tyvek? None of it because builder was cheap. Upstairs windows are new and downstairs windows on the north side will be covered with plastic from outside so they won't let wind through.
Air sealing, is simply caulking any gaps & cracks or filling them with expanding foam that can leak air. An example, is caulking around the place your garden faucet plumbing penetrates to the outside. Or, plugging the holes in your attic where the wires run from your lower floors into your attic. The big ones I found were where my plumbing vent stacks penetrated the floor of my attic. I had a one foot square cut out of my attic floor to fit like a 6" round pipe. Also, my chimney penetration had about a 2' wider opening than was needed. I closed it off to within 2" and followed their guide using metal. BTW, insulation is usually bad at air sealing, you need something solid like the spray foam, or caulk, or huge gaps I seal with drywall best I can and fill in the remaining cracks with expanding foam or repeatedly spray expanding foam to close them.
Warm air can hold a lot of moisture, cold air can not. In winter, your house air is humid, any air leaks causes your warm humid house air to escape and as it does it cools down and is unable to hold the same amount of moisture, so the water condenses out of it. The more you insulate the less moisture your house can handle escaping. After insulating without air sealing, you run the risk more moisture is condensing than can work it's way through the insulation causing a buildup of moisture and the health problems that creates, also moist insulation is not as effective as dry, and air movement through insulation reduces its effectiveness.
The normal steps that I used was www.energystar.gov/ia/home_improvement/home_sealing/DIY_COLOR_100_dpi.pdf and don't let the first picture fool you, those people are just way too happy about sealing! Air sealing takes years... I keep finding new things I need to caulk, etc. or wire penetrations I missed. I recommend you get a can of expanding foam, it's great at sealing because it expands so much you're almost garunteed to close any leaks with it and you can seal up pretty large gaps. But, the stuff is unimaginably sticky, don't use it in the living area, the stuff turns flourescent orange over time, and difficult to use because it has to be upside down to dispense, and for the most part one time use so, if you start don't stop until your can is empty. You can go about 30 minutes without using it, then you better waste some else it starts to seal itself in the can. But, it does a great job of sealing air gaps.
Thanks I got it. I know Great Stuff (polyurethane expandable foam). There are Latex foams as well, which are easy to cleanup and don't stick as well. I personally like Great Stuff. Reusability of Great Stuff is questionable. Those straws get blocked easily. I can deal with it putting long 1/8 drill bit and removing cured foam. Sometimes the straw breaks off the other part. Latex foam is harmless and those straws can be easily reused. You press latex foam it is flat. Great Stuff cannot be compressed easily.
Rhonemas,
Now I started sealing my basement and it is really tediuos and labor intense work. I will still have to seal my attic and fix some insulation screw ups.
