homefire - 18 September 2006 11:49 AM
Building the walls will block the heath you get from the unit.
You will need to burn longer and hotter to achive the desired
comfort level you are seeking.
I might get heavy-duty unit say Dutch West large and burn wood full power. Walls will absorb some heat, which will be released when wood stove will be off.
I don’t understand your thinking about time to build a masonary heater
seems if you have the tools ,skills, and knowledge it would be a piece of cake for you.
Well, I have a humble approach. I don’t want to underestimate any project. I assume that everything is difficult so I put my best with intensity. If projects turned out easy that is fine. I don’t want to say it was easy. I deal with different projects: plumbing, roofing, electrical, painting, woodworking, car repair, PC repair, phone line repair etc. I am master of none but I am doing quite well in any of them.
As far as masonry heater is concerned. Well, I fixed chimney last year because it needed to be re-pointed. Some of my brick layering was done pretty crappy. I started doing decent job on my fifth row of bricks. I asked my Brother-in-law to help me and he did much better job (really good job).
So my brick, tile layering skills are pretty low. I can deal with concrete quite well (I poured concrete chimney cap – weighing around 130 lbs), which was put on the top of the chimney.
Is there a website which show you how to build a masonry heater?
Is there a vendor that supplies some parts of masonry heater?
Are there any books available on how to build a masonry heater?
Are those masonry heaters indeed more efficient than NC wood stoves?
