I did some research but I could not find anything pertaining to my case. If you can provide a link to interesting article I would appreciate it greatly. Otherwise, you can put your comments, suggestions etc, please![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Based on some people suggestions I gave up putting wood stove in my basement (for now). Instead I would like to put wood stove (maybe insert) in my family room which has fire place. I would like to build massive hearth which would absorb lots of heat and radiate it later when wood stove will be off.
I was thinking of building a frame on the floor ( 2 x 4 or 2x6 if necessary ), puting 3/4" plywood or two 1/2" plywoods and pour concrete on top of it (1000 lbs or more). Than I could put tiles or stones on top of concrete. I would reinforce concrete using rebar or mesh. Can I pour concrete directly on plywood? Should I do it in sections? Can I put insulation underneath plywood (fiber glass)? Should I pour concrete blocks and glue it to plywood using construction glue. I would reinforce floor from underneath to make sure that floor would not be stressed too much (two steal pipes). How should I put massive concrete on the wall (maybe I should not). How do I insulate it in this case etc.
Any feedback, suggestions would be greatly appreciated. This is an awesome forum (very professional and friendly people).
EDIT: I also have lots of black locust shavings, sawdust (probably like 400 gallons of it now). I will still have probably another 300 gallons of it. What for can I use black locust shavings, saw dust. I dont' think it will be good for insulattion and it might not be approved by insurance (fire code etc). I know that R value might be marginal but it is still better than plain air.
