I just had my p23i installed and this is the second day running it. I'm trying to heat approximately 1500 sqft (my first floor although the stove is located in an area approximately 1000 sq ft that is the main heating area). My home is fairly well insulated and the stove is only able to keep the 1000 sqft open area at around 64 degrees. The stove is running on setting four and is definitely producing heat as the heat temp blowing out of the stove is about 340 degrees. Even the family room where the stove is, is only about 66 degrees.
Any thoughts or is this what can be expected from this unit? I was under the impression from talking with dealers and others that I would not have a problem getting the immediate area up and over 70 degrees.
Thanks.
Thanks.
