saladdin
Make sure you always carry a fuse tester with you if you ever think a fuse is bad.
Suggest one?
People tell me that I have a short Fuse...Is the short fuse credited to Edison, Tesla or Ben Franklin (Yes I still believe the kite story!)???
Also can my short fuse be fatiguedor not??
Perfectly sized pre-cut for the 13,8kv fuses in my bldg!That will cover a lot of fuses.
Eric
Words to live by.one hand in your pocket
(This reminds me of an old electronics device technician's advice to wear rubber soled footwear, and rubber gloves, don't stand in water, and keep one hand in your pocket at all times when the other is inside the case doing in circuit testing with the cord plugged in).
That should be marked on the end cap of the fuse. The manual says "A 6-amp “quick-blow” fuse (Part # PU-CBF6) is usedWhat fuse should my englander take?
But those look like 5 amp fusesNOTE: 6 amp fuse, all control boards can take this 6 amp fuse.
If purchasing locally, ask for a 6 amp, 120 Volt fuse.
[Add to Cart] [View Cart]
And then we wonder why fuses occasionally fail for no obvious reason.Copied from Englander, Yes the case reads GMA 5
