Looking to build a block and tackle double pulleys needs to be strong anyone try this and what pulleys did you use? useing it to redirect tree felling.
smokinjay said:Looking to build a block and tackle double pulleys needs to be strong anyone try this and what pulleys did you use? useing it to redirect tree felling.
Gooserider said:smokinjay said:Looking to build a block and tackle double pulleys needs to be strong anyone try this and what pulleys did you use? useing it to redirect tree felling.
Haven't done this myself, I think a come-a-long is a better solution, but bear in mind that you need to match the pulley sheave size to the diameter of the rope that you are using, and that the larger the pulley diameter the better it is for the rope.
Pay VERY close attention to the strength ratings on both the rope and pulleys, as well as any attaching hardware on each end, as a block and tackle can rapidly get to the point of exceeding strength ratings.
Gooserider
LLigetfa said:I'm a come-along kind of guy too. I am thinking of getting a come-along that uses a nylon strap instead of steel cable. Getting fed up with trying to spool the cable carefully so as not to tangle and fray it.
I use both rope and steel cable depending on the situation. I generally pull on a rope to get a tree to fall but for safety lines where I need to prevent a tree from falling in a particular direction, I put my faith in 1/2 inch steel cable and heavy chains. If I have to anchor to a live tree though, I use nylon chokers. I sometimes will screw in a guy anchor like what hydro utilities use.
Gooserider said:I don't know about doing that - my feeling is that I won't try to drop a "danger tree" (one that is positioned such that it's preferred fall direction is likely to endanger valuable property) - I will leave those to the pros with the cranes and bucket trucks to take down in pieces...
If I DID have to do something like that, I would probably put a line or two on the tree and winch it over w/ come-a-longs or some other sort of winch until I had a definite lean in the direction I wanted, and then cut it VERY gingerly while watching out for any signs that the trunk would want to kick back when the tree started to go... I wouldn't want to use a block that was relying on someone to hold tension on it, as they could let go at the wrong moment...
Gooserider
Not really. This is what I was talking about.smokinjay said:here one that looks like what your talking about http://www.baileysonline.com/itemdetail.asp?item=21700&catID;=
Ja, I've thought about having the option to pull lots of line fast, something you can't really do with a come-along.smokinjay said:plan on using a friction device on one side and a block and tackle on the other side it would grab slack if need be much faster
LLigetfa said:[]Ja, I've thought about having the option to pull lots of line fast, something you can't really do with a come-along.
DMX_512 said:smokinjay
You will probably want to use a 5:3 (head block with 5 pulleys and a fall w/ 3 pulleys)block and fall at least. You can eat up an incredible amount of rope really quickly. Even a 3:2 will go through a 100 ft rope quickly an only give about 30 ft of lift (read distance from the head block to the dead end of the line). That might no be enough distance to keep the rigging away from the tree as it falls. I myself have a couple of trees that I have thought about using the same method on.
I would also consider using a come-along, span sets(nylon slings), steel rigging cable with thimble eyes in each end and 5/8 shackles. Fortunately I have access to all of this equipment to borrow / use as I like. I have no idea what the cost to buy would be from Fehr but like most stuff in the rigging department ....... none of it is cheap.
Here is a link to CMI website they have all kinds of pulleys, climbing, rigging stuff
CMI Climbing / Rigging
Here is Fehr Brothers, Steel rigging, span sets etc...
Fehr Brothers
Blue Water Rope....all kinds of ropes check out the static line section
Blue Water Ropes
Be safe
Keep us posted
LLigetfa said:Not really. This is what I was talking about.smokinjay said:here one that looks like what your talking about http://www.baileysonline.com/itemdetail.asp?item=21700&catID;=
http://www.lug-all.com/pages/webstrapconvert.php
kenny chaos said:LLigetfa said:[]Ja, I've thought about having the option to pull lots of line fast, something you can't really do with a come-along.
How about a winch or cable to tractor?
Lots of options.
