what did they do to get the 30burn times ?? did they redesign the stove and if so what was done
Out of curiosity, what kind of surface temp are you guys pulling for these 18 to 30 hr burn times? Anyone have a good idea of typical surface temps on 4 to 5 hour intervals through the burn cycle?
I'm going to need a second stove next year...and I could take or leave the looks of the bk personally, but these burn times are hard to ignore.
For a 24 hour burn my stove top averages around 400 degrees. Starts out in the 500's and ends up around 300 with the cat still in the active range.
Yeah I saw that one, but it only details from 8:25pm to 11:55pm - plus stove is down to coals by 5am and coals had to be raked and air opened up to pick stove back up to 400, then down to a "stove hotspot"(?) of 350* for a morning reload around 7am...
so roughly 10 hour burn time on that load and only had surface temp recorded for the first four hours, unless I am missing something?
If for the sake of discussion we consider 350* surface temp the cutoff for useful heat, how long will the princess burn - dialed in and untouched - at surface temps that are in the useful heat range? Are you guys getting 18 to 30 hrs at 350* plus? If not, how many hours are you getting above that temp?
geez highbeam ,no good reads on the hearth so ya had to go back to the bk site and re-read the brocure/owners manual for probally the 100th time
good find. i bet mine would go 30 hours on low stuffed to the gills .although i dont have a super draft!
Something is wrong with your stove Nate. Your burntimes are always way too low and your data pints are so far from the majority of us owners that you really must have something out of whack. I don't know what it is but I suspect too much air entering the firebox from either the door or the stat.
Man that's awesome...same temps I get out of my Jotul...but I'm down to 300 after about 10 to 12 hours hours
Just remember for a cat stove the stove top temps don't tell the whole story. My temps were taken right on top of the cat, as you move away it cools down and the sides were running 250-300. IMO A long 24-30 hour burn puts out about the same heat as a single 1500w electric baseboard which is fine for warmer 40-50's days but doesn't do squat for colder Winter days like I have today.
And I suspect that is what Nate has to do all the time with his outdoor temps, hence shorter burn times.
Is it safe to assume that those with the really long burn times have tightly sealed homes?
