One thing I've observed is the burntime goes down a bit as the temperature drops outside, I think due to a stronger draft. But that's fine since you need the heat anyways.
That doesn't sound right. If draft is stronger, the fire will burn hotter and the thermostat should close accordingly, yielding a similar burn time.
My Ashford 30 smokes like the devil during the first 5 minutes of a high burn after a reload with the bypass closed,
Is the cat still in the active zone when you close the bypass again after a reload? How far open is the air for your "high burn?" It's possible to blow smoke right through the cat before it has a chance to burn, if you have the air wide open.
I would like to have the peace of mind of a non-electric wood stove, but the emissions have to be very low for being an urban burner. Please tell me if your Ashford 30.2 with 0.8 grams/hour after startup, only emits visible moisture?
Some of the pre-2020 non-cats emitted up to 4 g/h..there is no visible smoke. Some non-cat users report the ability, from a cold start to have the air cut back, their stove cruising and burning cleanly, within fifteen minutes. Hard to do that with a cat stove. Other cold-start techniques such as a "top-down start" will allow for a more smoke-free startup.
the regency is definitely doing a great job warming my house for 12 hours house temp starts to drop after 12 hours still not to shabby, the house is 2,221 square-foot with lots of windows, the room where the stove is in has 8 windows and two 6 foot French glass doors. There is no way I can go 24 hours of keeping the house warm I imagine I can probably have some hot coals. Still would love to here from BK owners how there stove burn times are so I have an idea of how long till the house temps drop.
Last winter we had some realtime cold weather reports of 8-12hr burn times in their BK stoves. It's a simple matter of the house's heat loss. Adding a cat stove does nothing to change that. It may eek out 5% more efficiency and that is great, but when heat is demanded, the technology difference becomes moot. Where these stoves shine is during shoulder season burning and in very well insulated houses. They do this very well by burning smoldering smoke in the catalytic convertor. A non-cat should not be burned so low that the fire smolders.
Wolves, if you're looking for some kind of magical stove the will double your burn time while putting out the heat that it sounds like you need, I think you'll be disappointed. There is 'X' amount of heat in a load of wood, period. There's no way around the laws of physics.
Despite reports of long burn time, like begreen said, if you need heat, those are out the window. For shoulder-season burning, I can run my cat stove, with a fire box half the size of a BK, very low for a very long time. Plus, when it finally burns out, house temp drops very slowly, even though my insulation and air-sealing aren't good...it's not cold out in shoulder season.
I started the first Bk performance thread, I’d start there.
Start there, then read
all the BK threads to discover other BK features that you may not yet be aware of..
![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
