I wonder how many stranded travelers might not have died in the wilderness, if they'd had a portable cell phone antenna with them so they could have hit a distant tower...it is a cell phone booster antenna!![]()
You need to verify the moisture content of your wood, and go from there before spending money unnecessarily. I know you said your wood was Pine, split and stacked in a shed earlier this year. As was mentioned, it might be pretty dry if the Pine was from dead trees. But if the trees were live when cut, then split and put in the shed where there's no wind, it's possible the wood hasn't dried enough yet. Moisture running down the glass is a bad sign! If you bought the wood instead of cutting it yourself, it may be hard to tell if it was live wood, or what. Get a $15 moisture meter from Harbor Fright, split several of your larger splits, and test on the fresh-split surface. If your wood is indeed wet, maybe you can find some dead wood now that you could cut and use (if you or a friend has a saw and a truck.) There's a lot of beetle-kill Pine in your area, I think. You could buy some Northern Idaho Energy Logs (NIELs) but they are expensive. Gas station wood may or may not be dry; A meter would tell you this.woke up this morning with my fire out because of moisture and the glass is all back with run marks all over it!![]()
Once you have confirmed dry wood, the next thing is to determine weather the cat is OK. With the former owner burning chemicals through it, it could glow once in a while, but still be very weak from poisoning and not be able to stay lit at low draft settings. There is also a cleaning procedure for the cat which may help restore it somewhat. It will only clean ash that is stuck on the cat surfaces, it won't restore a poisoned cat. (broken link removed to http://www.condar.com/combustorcleaningmanual.pdf)
In the meantime, get that bypass gasket fixed. If you're getting a metal-on-metal sound, it's probably not sealing. And reset the thermostat knob and make sure it's not slipping on the shaft.
