I mentioned the testing of the new door and the BK rep verifying the location of the leak. During our conversation he mentioned he owned a older model King and has no issues with smoke smells. I asked if he would use my draft gauge and make measurements at different temperature settings so we can compare. Long story short, overall his draft measurements are not a good as what I measure in my installation. I use the phrase "as good" because of the negative values in draft measurements make it confusing.
From the start I have not found draft specifications however decided to find the manual for the older King; to my surprise these measurements are in print in the old manual (attached) and for some reason removed from the new manual .
This is the requirement in the manual for the older king:
"Flue Collar 8” I.D.
Recommended Flue Draft .05” water column (on high burn)
.02 -.03 in. water column (on medium fi re)"
I can tell you in my setup there is .02" water column when the chimney is stone cold, kindling brings it up to .05 never mind low burn; at high burn I see .07 - .09 depending on outside temperatures.
What the hell is going on here!
		![[Hearth.com] Blaze King King 40 New Cat Stove 2020  Smoke Smell [Hearth.com] Blaze King King 40 New Cat Stove 2020  Smoke Smell](https://www.hearth.com/talk/data/attachments/290/290222-cf9a8c9f564f487527463e77d5a7bffa.jpg?hash=-6V8ebiKb1)
