I don't have to keep the door open more than a minute or two to get the kindling going. Makes me think the draft my be an issue here, if this seems necessary to get the fire going?
No way does the manual say to run the stove with the loading door unlatched for 25-30 minutes. This is a recipe for disaster. You're nuking your system every time you do this.my biggest obstacle was following the directions in the manual to run it on high with the door unlatched for 25 to 35 minutes.
This is the most asinine thing I’ve heard! It’s offensive! With 10’s of thousands of BK’s in operation, do you actually think all our houses smell like creosote? He’s way off.I have talked to another store who sells and installs Blaze Kings and he said the blaze kings usually have a creosote smell, every time he walks into someones house he knows if its a blazeking.
Sorry I'm late to the party but I just wanted to mention that, although in many ways a different beast, I have noticed a smoke smell from my VC cat stoves on occasion even when the draft is strong, fire is burning well, etc. Definitely coming from the door. I finally traced it down to liquid creosote that had soaked into the fiber of the gasket on low burns, and started pyrolyzing when it met the room air on the other side.
The solution was multi fold, and included charring the load longer before turning down, as well as getting another year ahead on my wood seasoning.
I've observed that the complaints about smoke/creosote smells from cat stoves in general tend to get beaten down on this forum as some sort of user / install error, but it is a real phenomenon and as far as I can tell not draft related.
Yes absolutely, although I should add that it's not a 100% perfect solution, I still get the smell now and then. It's tolerable. However I would not suggest that my previous operation of the stove was the "root cause" of the issue.Though, your own solutions do pertain to user behavior.... (Charring time, seasoning time).
Just to clarify, I did not make that statement, that was quoted from BLAZZED.This is the most asinine thing I’ve heard! It’s offensive! With 10’s of thousands of BK’s in operation, do you actually think all our houses smell like creosote? He’s way off.
I realize that. Sorry if it sounded like you said it.Just to clarify, I did not make that statement, that was quoted from BLAZZED.
I guess I missed the part about you found out for a certainty where it’s leaking.I am interested in knowing more about the stain pattern on the glass and would appreciate any pictures showing the stain, mainly the stain after longer slow burns.
As far as the actual point of the leak; for anyone that suspects there is a small leak I ask you make a cone with aluminum foil and use it to find the actual leak location, which I believe will be in the upper left or upper right corners. Using the cone really helps by keeping you away from the stove and funneling any gases directly to your sniffer. My BK representative used it and quickly realized the exact location of the leak, in my case upper left.
The problem with the silicon gasket is the operating temperature is too low and the gasket fails is short order. I installed one to do some testing but it failed after a few burn cycles.I always thought a silicone rope gasket would solve most problems. It would keep creosote resin on the inside of the firebox and not allow the gasket to become saturated and sneak through like it does with traditional rope gaskets. Link for relevance:
Fiberglass with Silicone Rubber Coating Gasket Seal Rope
Fiberglass with Silicone Rubber Coating Gasket Seal Ropewww.abthermal.com
Loading door gasket leaking, admitting excess air into firebox | Replace door gasket and/or adjust door. See “GASKET INSPECTION” |
Wouldn't the draft gauge indicate that? And if that is the case than the stove air inlet would be the exhaust and the chimney would be the air inlet. It seems if this were the case it would be quite obvious. Remember, the leak is not intermittent but continuous whenever the stove is actively regulating the temperature.You are correct, the stove should pull air in if there is a leak. In the event of smoke or smell spillage, attention generally turns toward a negative pressure situation within the home.
