$275 a month for propane is just insane to me. I feel like I'm just giving the gas company money and I don't like that. Hence the wood.
Well, yes, it sort of is, if you compare it to being able to get wood for nothing.
But it is not really terribly out to lunch for a monthly fossil fuel or electric heating bill, relatively speaking. Which is kind of telling me that maybe your house could be better, but it isn't 'bad bad'. Would also seem to indicate that the BK should be doing better heating the place - for whatever reason.
I have an electric boiler for backup heat. If I had to use it full time, it would likely cost me somewhere around $25/day when it is cold out. My father has oil and a pretty tight house - he'd be over $300/mo.
I'd like to thank everyone for their help. I'm going to try some "true" dry 2x4's or pallet wood and see that the difference is.
Hence the wood.
After reading everything here the King is more of a radiant high heat output monster, good high heat over a long period of time. My old Timberline was a fire breather in that it put out a ton of heat in a short time, allowing me to heat my place very fast. Now the difference here is my s***** insulation allows the King's heat to go right out the walls or through the ceiling into the attic and gone. So, my solution is to spend a few grand on insulation and keep the King, go back to a Timberline or Fisher or something of the antique era and pony up for more wood. That's about what I can do.
Are these temps with stove wide open or dialed back ? I are those temps typical and your not satisfied ? Or are these temps with known dry wood such as pallets or bio bricks ?Well,,,,,, is'nt that special ??
My reply above was to this post , not sure what happenedStove temps:
566 on top
back behind the flue
480
side of stove
467
pipe starts at 363 to 233 at ceiling
Does this help diagnose any problems??
Yeah he replaced it with a condar one without the gasket but it needs a gasket.You said you bought the stove used. Have you ever installed a new cat? That is what makes these stoves work.
I see the same thing over and over again on this site.
People blame the stove for their house not being warm enough, and will try everything under the sun to make more heat except insulating and air sealing their house.
That is the problem, not the stove.
Wood is coming in at 21 or less on the meter. A mix of oak, hickory, ash, black locust.
If you’re measuring 21% on he outside of an old split face, you are likely burning wood that’s over 30% (or even 35%). That’s not going to work in this stove, period.I've never measured a fresh split cord. I'll try that.
I don’t buy this. He’s living in 1800 sq ft, with half of that closed off. Heck, that’s not a house, it’s not even a big room!Well, the OP was happier with a smoke dragon because he needs insane heat output.
The King can heat many times that, in most climates. Heck, one of my Ashfords is heating at least 2.5x his space with no aid from central heating, and bleeding out to 4x his space with some aid from the central heat. That part of the house isn’t “poorly insulated”, it’s totally un-insulated.
I have seen stove top temps, but no mention of cat probe temp? That’s the only one we care about, here.
ya, agreed - i've spent over $500/month up here...IMO $175-280/mo heating just on LP doesn't seem all that extreme?
We don't know what his envelope's like. Maybe part of the roof is missing.
A King could heat 900 sq ft without any roof! My kitchen is bigger than that!
Ok...taking a booth building break.
1) Condar is flat out wrong. You need the gasket.
2) Are you locking down the bypass
3) Get nominal chimney length to 15' and it will help. That's in the manual.
4) What is behind the brick wall behind stove. You must maintain clearances to "nearest" combustible even if you have a non combustible surface.
5) If that brick is real, prior post is correct. Thermostat spring could be influenced by radiadating heat off the brick.
7) I have a much older house 1895, 30 x 25 living room with 8' ceilings and an adjoining room. On high, with proper install, proper operation and NIELS or 18% or less m.c. fuel, bring the room to 90 degrees very, very fast.
8) Dual blowers make a tremendous difference in getting heat out into the living space.
In conclusion, I have a buddy in a yurt that has the smaller Princess. He lives on the slope near Kotzebue AK. His yurt is 70F when -20 outside.
Go with 1-8 above and report back please....
Thank you for reaching out to this forum. It will help.
