BeGreen said:The teepee is just to get 3 of them burning well. Then you need to create a solid stack of bricks surrounding the teepee as shown in the link provided. Try to avoid airspaces in the stack. It's the tightly stacked bricks that give the slow burn. But don't overload the stove, that's a lot of btus.
RingOfFire said:BeGreen said:The teepee is just to get 3 of them burning well. Then you need to create a solid stack of bricks surrounding the teepee as shown in the link provided. Try to avoid airspaces in the stack. It's the tightly stacked bricks that give the slow burn. But don't overload the stove, that's a lot of btus.
I only use the teepee lighting method for bio's if kindling wood is not available. There is a much energy that it takes to heat up a firebox. Do like Begreen suggest and build a tight burning mass. Due to the size of my stove and fall type weather I do 10 at a time and get 8 hours heat with stove top 200-250. This will increase as it get's colder.
BioPellet said:BeGreen said:The teepee is just to get 3 of them burning well. Then you need to create a solid stack of bricks surrounding the teepee as shown in the link provided. Try to avoid airspaces in the stack. It's the tightly stacked bricks that give the slow burn. But don't overload the stove, that's a lot of btus.
Guys, three bricks might not be enough. I say on my instructions that you need 4 bricks, 3 leaned together around the newsprint and one layed flat on top. The three around the newsprint provide insulation, the one on top catches all the heat and reflects it back into the ones below. Sometimes I need to blow on the newspaaper and sometimes it takes a second try but I find it to be the easiest way in general to get started
BeGreen said:I found a supercedar worked the best. No muss, no fuss. The BioBricks were a little reluctant to get going and need a longer flame than newspaper could provide.
jjs777_fzr said:been using biobricks for a bit now and have come to the conclusion it really does matter how you stack the things!
stacking close together and flat the stove produces low temps but last a long time...then leaves a hot bed of coals that last for quite some time so I can throw wood (or more bricks) on top and it catches real quick
If I stack at an angle against the back of my stove (same # of bricks - say 8) so the short side is up/down it will produce a much hotter flame
Compare temps of 250 vs 500
Not sure how this can make THAT much of a difference but I been observing this behavior for a few weeks now and am convinced it is consistently reproducable
cost is definitely too high
stacking convenience is unbeatable (1 ton goes right under my 2nd flr stairs! and I could prolly fit 3 tons same area) is better than anything and no comparison to wood
amazing how the wife factor must be mentioned as well - she loads the stove now! with biobricks
I think the best thing is to use them w/wood
the wood gets the stove hot and the bricks keep the stove warm longer so its not so hard to get the stove up to temp next time
BeGreen said:Yep, frugality used to be considered one of the cornerstones of patriotism. Now we're told it's our patriotic duty to go out and shop.
