Big rock in a hole. How to remove?
Wow, we are told that will rot the pressure treated off. Funny how things vary from region to region.
In the case you mention, if they want to be pricks, they'll have us pour a sonotube full of concrete with a galvanized post holder at the top, and mount to that.
That connection then, the post holder to the post, will provide nearly zero strength against the post falling over. Unless there is a very long sleeve that runs over the post, like several feet, the lateral strength of the system is ruined abd all you get is vertical strength.
I didn't plan on concrete backfill, just the footing cookie under the pole but the engineering was very certain that it was required. More than one structural engineer since I got three bids. To be fair, my location must design for 115 mph wind loads and the building is 30x60 so a lot of exposure on the big side with not much width.
I'm guessing the narrow nature of the hole may exclude a feather/wedge from being used.
I'd try a rotary/hammer drill and see how far an 18" bit will go. You may go through the stone and see soil tailings - if not than time to call in the backhoe
They made you backfill the hole with concrete? As in surround the pressure treated post with concrete? If so, around here encasing pressure treated in concrete would be a big no go.
pen
Pen,
There are multiple pressure treatments and any ground contact rated can be set in concrete.
The normal PT stuff is for above ground only, no ground contact allowed.
Pen,
Yep - generally 3 ratings. Above ground, ground contact/underground and submersible (water, think piers, docks, etc.).
Lowes sells 2 types the higher rated wood is more expensive.
And I believe they can special order the third (at least around here they can), but they don't stock it.
Burn ban going on right now after 49 days with no rain. That can't happen. I'm thinking jackhammer or backhoe.
Think both. Where's that excavator that tore down the old garage? Many mini's are able to take a hammer attachment. Or you/the company could rent one and pound through.
I called the guy with the excavator. He was bummed out and chagrined to tell me his young apprentice had flipped it. Not sure when it will be back online.
After spending most of a day flaking granite with a jackhammer it was decided that this rock is staying. The engineers are penciling out a rebar and cement overshoe solution. And our project slips another week.
Cool, you found one of those huge granite boulders. They are so rare that there are specail names for them, like irregulars or oddballs, or something. We have to write contract provisions for just in case one is encountered while putting in a water main or something.
I have a property full of them. We have 2 large ones that we discovered when landscaping for the greenhouse. They are like 60" x 40" x 24". I was amazed that the guy was able to move them with his excavator. And many more 1-3 man granite rocks were discovered and used for garden walls and features. The local gravel yard is also full of them. I think they grow here.
We affectionately call them "donikers". I hope it is not some sort of racial slur or anything it is just what the construction guys have always called them and the name sticks. A big old donicker fell into the trench from the sidewall.
