How about running just one row N-S in the center, and fill the remaining area E-W, in the brace area?using knee braces when attaching my book-ends.
Jao : I like that concept.
Problem here is you need a good lid as it snows like mad.
That's why I went to centering the blocks under the cutouts, to distribute the weight better. You use more blocks though. We've got a 3-wide pallet row going at my BIL's house. It will have 2 summers before he needs it. Fresh Hackberry in the center row, dead Red Elm on the outside rows on the first two pallets, then some dead, but fairly wet, White Ash 3 wide on the next two pallets. Never went 3 wide before, but I think it should be OK. Will top-cover.I find 6' vertical of green wood is about the limit for pallets with cutouts for forklift forks....read many times that a third layer of wood in between the two outside layers, the third layer doesn't dry so good.
I stopped using pallets 2 years ago. I now use the Cinder Block and 2x4. They are Cheap and Portable.
How many racks like this do u need for 1 cord of wood?
I love that! How stable are those cinder blocks with the uprights?I stopped using pallets 2 years ago. I now use the Cinder Block and 2x4. They are Cheap and Portable.![]()
Hah. Well, that's always the concern, right? I wonder if a couple of hurricane ties or something to secure the uprights to the crossmembers would help. Looks like it would be a good idea to wedge something in the block holes to take up space. Or use 1 more block per side and face them in the opposite direction.Minor construction errors reveal failure rates soon enough.
Make them 24' so each row is a cord. Or do shorter and tallerIt depends on how long you make the racks. If you use 8' beams across the bottom and stack them at least 4' high off your beam, then you have 1 face cord (1/3 of a cord). This is assuming your splits are 16" wide. So in that case, you would need 3 rows to make a cord. Depending on room you could also make them 10', 12', or 16' long too.
This is what I do too.Make them 24' so each row is a cord. Or do shorter and taller
Too heavy to move...I put some spare plywood on top of them...all set for the winter now...I hope!Do you move those pallets with a FEL? My little L2000DT wouldn't budge something that size.
