GVA said:
Do I need to put this up again?
http://www.mywoodenergy.com/2.html
Yes theres more around here that are cheaper, but run this through the calculator.
Sure, no problem - as you as you calculate based on the $8.90/bag that started the thread
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Both are ridiculous, and everyone knows it.
I just think that the 25 MIL BTU for hardwood should better represent what most people get, as not many people get hickory or orange osage or other High BTU woods like those to be factored into the average...........
Right - I agree - 25 mil BTU is a more typical average among hardwoods, and that is what is in the calculator per your note. Just like it doesn't use the highest or lowest pellet value, it doesn't use highest or lowest hardwood value.
And as far as the heat going out the flue of a pellet stove I can hold my hand in front of the direct vent discharge and not worry about burning it... So one would think that the input btu's were efficiently removed to become BTU's that went into the room and not up the flue... Right?
It seems you won't stop until you can prove that wood has more BTU input than pellets..... But as I hinted at earlier If you took a cord of hardwood at 25 mil btu and turned it into sawdust and then dried it and made it into pellets are the BTU's Higher or lower?
Let's assume that when it was cordwood it was 20% mc and as pellets it is alot less (i think 5% not sure though) BTU's are lost due to burning off the moisture content..... So efficiency of the stove is not even in this equation........
Again, you are only partially correct... If you read the university extension site carefully, you'll see that when they say 25 million BTUs per cord, that is
at 20% moisture content which means they have accounted for that evaporation in the number. What is not accounted for in this discussion is the residual moisture in the pellets, so that kind of works against your argument here, but I agree it is relatively small.
Listen Colin The point here is If you never tried it don't knock it...... Are you saving more money than me by burning wood? YES
I agree, based on my local market conditions at the moment. (although I cut my own, I can buy for $150/cord...)
Am I saving more money by burning pellets rather than NG or OIL? YES
Depends on your oil price relative to pellets.
Is my house warmer by burning pellets over NG? YES
Depends on how much of each you burn, but sure, burn enough of either and you'll do fine.
Now if you want to move closer to the northeast, I can tell you you won't be paying $75 a cord and you may want to buy a pellet stove if you were in this area. :bug:
Maybe if you can only buy wood at $300+/cord, but that is highway robbery around here, and I live less than 100 miles from Manhattan - not exactly cheap country. Again, in your local market in the Northeast, at $250/ton for pellets, you can't make the case unless you have exorbitant wood prices. Remember - the $300+ you quote for wood is the highest example you can find. The $250/ton I quote for pellets is an average from a website designed to help people track the pellet market in MA. Not exactly apples-to-apples - you are trying to make a loaded comparison that is rather silly.
Oh yeah and pellet prices are dropping....... and so is Oil but sorry to say there's alot of people who locked in at HIGH rates for oil because of the panic from last year. So they are the ones who are screwed, still paying $2.75 a gallon when you can get it for about $2.15 now.......
Should we stop now or do you want to keep going?
My main concern is that you have tried to find flaws in the calculator repeatedly, and your analysis was wrong every time, so it needs to be pointed out. Otherwise, users read this and walk away with false information. In this post, you again said something very misleading - you implied that the cordwood BTU values have to be derated for water. That is not correct. It is net available heat after accounting for 20% moisture. Important point.
The calculator will tell some users that pellets are a great deal depending on their local market, and a poor choice in others. And that is what it all comes down to - in some markets, pellet stoves are not very cost effective. And if cost is a major concern, hardwood holds compelling price advantages that rarely tilt to favor pellets. Too many people want to put their head in the sand and believe that is not the case and that pellets always save money. It's not that simple.
If pellets get to $150/cord on the east coast, it'll be a whole new ballgame... and the calculator will confirm it for you.
-Colin
