jebatty said:Have to add my "looks great - job well done" also.
When I saw your post that said 80' of 1.25, 45 L's, many T's, I began to think about pump head. Have you done a pump head calculation, equivalent feet, # of gpm you need to move to handle the btu output, size of circulator(s) you need? 80' + 45 L's (? T's - each adds 7'; + other fittings, valves, plate hx, etc.) adds up to about 250' of equivalent pipe length. 1.25 is normally rated at 14 gpm, which is 140,000 btuH at delta-T=20F. Line loss (pump head) for 250' is about 13' at 14 gpm. Take a look at your system design as to sizing circulators to make sure you get the performance you expect or need.
Gasifier said:Nice SmokeEater. Nice. Any flames yet?
SmokeEater said:GasifierGasifier said:Nice SmokeEater. Nice. Any flames yet?
If Murphy's Law doesn't put too many kinks in the works, I'm hoping for some fire by week's end. I've leaned not to be too optimistic on time.
Gasifier said:SmokeEater said:GasifierGasifier said:Nice SmokeEater. Nice. Any flames yet?
:lol: I hear ya SmokeEater. I started doing some research in January of 2011. Found this site a while later. Thankfully. Started planning a new boiler system with some storage. Fired it up October 1, 2011. And that was paying to have the install done after I got everything in place. It will be worth it all in the end. Will you have, or have you considered, a power source if the power was to go out? So that you can continue to run pellet boiler and circulation pumps that are needed? Just curious. Good luck with firing it up!
Gasifier said:Looks great smokeeater! I hope all goes well for you. That pellet boiler should be sweet. Simple, and low amount of work after all the initial install is done compared to heating with wood. How long do you figure that hopper will last you in the colder weather? I am not familiar with the pellet boilers.
