Considering purchasing a battery backup for my newer Harman P43. Any recommendations for my stove? Thanks!!
Very good point thanks!Have you considered an inverter generator? Battery backups are generally expensive and sort of a one truck pony. If you shell out the cash for a small gen, you can power a few other important items, such as your fridge and coffee pot They can also come in VERY handy for running power tools out of range of a house outlet, and on camping trips, etc.
If you're talking about a UPS for smoke free shutdowns, the APC BE750G is one of the models recommended by Harman.
Thanks Sam. Where did you get yours from?I put a APC BE750G on our new P43. We have a generator but with wife and I at work all day, I figured get the BE750G just in case power goes out before we get home.
Sam
Well, that may be true for some, but those of us using some Quads are trying to do exactly that, and can, for 1-2 days. So while the OP's question was for a Harman, it sounds like the goal may be to run the stove, not just shut it down. And that's likely something that needs to be pointed out and clarified. A simple vertical rise in the vent can prevent smoke, so a battery backup that does only a shutdown is of little use to many. Personally I think it's just bad design.Long enough for the stove to shut down and not smoke you out. You're not going to run the stove/blower off the battery. Not the point.
114 Amp Hour Deep Cycle. Think diesel truck or large marine trolling battery.I didn't think a battery backup would run a stove for very long?
What kind do you use?
The Mount Vernon AE is pretty unique because it uses 12 Volt DC motors and can directly run from battery power.I didn't think a battery backup would run a stove for very long?
A-Yup. A good reason to buy 'em.The Mount Vernon AE is pretty unique because it uses 12 Volt DC motors and can directly run from battery power.
Please post specs so we don't need to go research it.Any opinions on the APC model BN700MC 420 watt? Will this one be ok ?
I installed the APC BE 750G and tested it and the damn thing works! Bought it from Amazon for $80.99 with free shipping ( no I don't have Prime). I tested it by unplugging the UPS from the wall, and sure enough, the combustion blower started pulsing and the stove shut down. I usually run on room temp/ manual so upon power restoration would not restart the stove.
