DAKSY said:I don't think there is any need for a B'vent cap. It wouldn't
be any different than what you have there now. How much
MB is exposed above the roof? I don't believe you have to adhere
to the 10-2-3 rule with a non-solid burning appliance. I'm thinkin
maybe if you removed a section of the Class A, you might not have
this issue, as there would be less cold metal to inhibit your draft...
Thanx Bob,
I talked to a hearthstone dealer yeterday, and told him about the outside MB chimney. He also thinks that I have too much flue outside. Mine goes through the wall then up about 8-10'. He suggested putting vermiculite in between the flex pipe, and the MB pipe, insulating the flex line, and it may draft better. He said it "could" work. If not, I'd have to go through the roof, someting I was trying to avoid. I'll post the results of the insulation fix.
Happy new year!
