MBTU is shorthand for Million BTU.
That sounds pretty darn good to me. Ive read the average HHI for US houses is around 10,code minimum new construction gets you to 7 and super tight houses hit 5ish.
When I calculate mine I get 9.7 on a net energy basis, and about 12 on a gross input basis.(I never remember which is the proper way to estimate?) Not great but I think not bad for the age of the house and a lot better than the 12/15 values I calculated from before I started insulating and sealing. I'd love to get it down to 10 gross but that will be difficult with this place.
I use gross energy, that's what I pay for, so any reduction is $ in my pocket. I'm pleased with our house, built in 1977 but with R13 in walls and R5 foam outside, much higher than typical of the time, although the foam may have been added later. Attic insulation is just okay, but having a cape minimizes that area anyway. On the other hand, the access doors behind knee walls were simply a particle board with 1/2" gap at the top, and there are still so many other air leaks that I'll never get them all. I know my house is still far from ideal so I think that the "average" number of 10BTU/HDD/SQFT is misleading because it doesn't account for different use patterns. Our propane heat is setback daytime Monday-Friday, or if we're off for the weekend, while others keep their home at 75F 24/7 all winter long.
TE
). So the improvement to 12 gross is probably even better than it looks.
